RE: Eureka Banshee Build Thread
FB, going with the tri gear, I think barn door ailerons, and seperate wing servos.
Anybody given any thought to having the belly pan removable if using tri gear retracts? I suspect that a retract servo mounted on the bottom of the wing, with a removable pan, would make pulling the wing much simpler (disconnecting the nose wheel retract pushrod).
