RE: My new transmitter for baja
Even tho your Transmitter came with built in fail safe..It will not kill the engine...You should get the modified Diemaster Pico Kill switch...
All your built in fail safe will do is let you program to apply brakes and set the throttle to low position....Your engine is still running....
Low battery power ..Or lose of battery power you will have a runaway RC Unit.......The Kill Switch from DDM..Daves Discount Motors
is like $39.00USD......Just thought I would offer you some Advice.......AKASlawhammer
