ORIGINAL: chris1379
The E-flite S75 gears are the same as the 8g analog gears except for the spline gear. They're $2.99 but you can find them at any hobby shop.
Chris
thanks. that's good to know. as long as the gears affected are not the spline and the one after it, this will be a good fix.
it's been raining here for the past 4 days and will continue for another 4, so i can't try and see what's happening with the out of phase problem and if broken gears were at fault. i even programmed some channel mixing to see if that helps. if not, then i guess i'll go for a CNC head, not that i really need one at this stage of learning, but it's annoying to have to compensate for the thrust vector being off.
