RE: Sig Kavalier Build
I have made some more progress on the wing. It is now finished for the most part. I did make a few changes detailed in the attached photos. I located the aileron servos in the mid-wing section and plan to mix in some flaperon. Not that this kit really needs flaps, but to help introduce the use of them to my son Collin prior to flying his first warbird. Second, I extended the wing-tips to fair with the trailing edge of the ailerons. This should help reduce turbulation at high speeds and minimize the possibility of flutter.
