RE: improved vibration
Yes, the back of the muffler has a bracket welded to it that uses the lower mounting bolt holes on the engine so it does not move. I have run this set up with great success and It sounds awesome.
Although my engine configuration may be different then yours, (starter on the side) Let Kelvin know when you order, (stock or rotated). He made the bracket to fit my setup.
