ZDZ 80rv ignition
Ok I bought yak with a ZDZ80RV. I cannot start this engine using the 5-5-1 method [:@]after 4 flick lots of fuel comes out the cab, A friend of mine check the ignition system and found the sensor working but the ignition box burnout (no spark) .
#1 why is the Carb flooding offer 4 flick??
#2 Can I use a DL50 ignition unit? The ZDZ sensor works ok, Is there a timing difference' between the ZDZ ignition unit and the DL?
Thanks guys
