Hi all
The Enya X45 TV AL-Chrome is fixed, the lock nut as showen in the pic of a Enya 2 needle carb has done the trick.
What Fuel Do I use ? ...Just Standard 20% Caster (Castrol M) with 5 % nitro.
What prop ? The engine runs fine with a 11x7 Aviomodelli Glass filled prop.
Hi Ed Cregger ....If your engine is lacking midrange Adjust the Hi Speed needle to the right mix :-2 clicks rich then adjust the midrange needle
for a stable transition from Idle to half and you should then be very close.
Photos are engine in Kaos 40, Kaos 40 and Carb showing lock nut that was missing on mine, that caused all the issues .... the needle was free to change on its own confusing things[
Johnkpap
