ORIGINAL: zac137
ORIGINAL: Gray Beard
I'm using the 9-C but I have found if I'm using extensions to lengethen the wires I have had that problem. I no longer use extensions but make my own lengths by soldering wire between the servo leads to get my length. By having the servo wire soldered i no longer need to pull the extensions and clean them so it's a winning way for me to go. If you are using extensions you may want to pull the servos and wire them directly into the RX and see if it cures the problem, if so then solder and forget the extensions.
GB- thanks for the info. I am using servo extentions, but they are brand new. I will give your idea a shot.
It's just an easy and quick thing to check, just another thing that can slow servos down. My old radio defaults the second elevator servo to ch 8 so I just plug in and activate 8. When all else fails I do have the match box for my bigger or more advanced planes/set ups. I have only programed one plane with your radio when the radio first came out so it's been a while.
