My TV only has coax antenna jack
Will my TV work with a wireless cam reciever? My old TV doesn't have an audio or video rca jack. All it has is one coax cable antenna jack. I'm using an rca/coax adapter to hook it to my tv.
I have two wireless cams now that I can't get to work and I'm thinking that this is the problem.
RE: My TV only has coax antenna jack
ORIGINAL: Shagnifico
Good Luck,
GA
www.markertek.com
GA
My camcorder has one AV jack, and one DV jack. Won't work either?
http://www.rcuniverse.com/forum/fb.asp?m=3667109
Everyone is getting closer.
You have a composite NTSC signal out of the receiver. That's a standard used in North America. But your TV needs RF in from a high frequency source. No amount of cables are going to make it work unless you convert the composite signal into the RF. This is common so there are many options available. Here is one and I'm sure you have a Radio Shack in town.
http://www.radioshack.com/product/in...entPage=search
Dan
Dan
GA
Yep. That's why I said he could use a VCR as a converter. But, I would much rather use a smaller device like what you provided.
ORIGINAL: randall1959
It would be less headache to just get a small cheap tv set with
AV inputs.
AV inputs.
After trying a few adapters that didn't work, rca to coax, rca to 1/8" .. Didn't work, so I bought a small portable lcd tv from radio shack. I made sure that it had AV jacks. Well guess what, the AV jacks on the lcd tv are 1/8" mini plugs. The cable from my wireless rieciver has rca jacks, ya know just like every other normal AV cable. Radio shack didn't have a video rca to 1/8" male adapter, neither did circuit city, neither did best buy. So the lcd tv is shelved, If I can't find adapters for it soon it's going back. Then finally while I was in Best Buy and picked up a small ac/dc tv. Works like a champ, not as GQ as the lcd tv, and really kind of heavy for field deployments. But it's good for using at home in the motor pool.
BTW, ever notice how overpriced everything is in Best Buy? SD cards that cost $29 at circuit city were $60 at best buy. I guess that $30 BW tv was cheap because it was a low demand item.
GA
Yep. A new portable monitor was the best choice. I can't believe Radio Shack didn't have that adapter. When they do have it, it ain't cheap. BNC > RCA adapters are around $3.
ND
ORIGINAL: Sky High
yup, they all did, they just don't know it! the 1/8 video is nothing but your typical 1/8 to stereo RCA audio cable, probably the most common cable out there. one side is video, one is mono audio. (IIRC, i think white is audio and red is video) yeah technically there are real video cables that have the correct color coding and impedence on the video line, but you will not notice a difference using 6 feet of this instead of the real one.
