Frequency Board
My Feedback: (12)
IL
Frequency Board
Our club is looking into putting up a new enclosed Frequency Board at our field.
Is there a company(s) that we could buy a ready made one from?
What do other clubs have?
We currently have one that is in a pistol case and we get it out of our storage shed for use.
Banned
My Feedback: (9)
RE: Frequency Board
A system that is quite popular at clubs around central Florida is pictured. Simple to make from PVC pipe, Ts, and aluminum tube, and aluminum angle to clip the pipes to as they are rotated up and held with the individuals frequency pin. Numers are from stick on numbers available at places like Office Depot.
IN
RE: Frequency Board
We have one that a club member built out of wood and the front cover folds down to reveal the board with clothes pin frequency tags listed with each channel and a place to slide your club card in. I don't have a pic right now but next time I am out there I will take a pick for you. It can be loacked as well so non-members can't play with it or vandals destroy it.
It is approximately 36" x 36" x 4" deep.
My Feedback: (12)
IL
RE: Frequency Board
Thanks guys.....
I did a search just in the CLUBHOUSE section and found some ideas too.
Thought I saw a magizine article where a company has a ready made aluminum enclosed FREQ BOARD.
This would be ideal, however I do like the ideas suggeted already........keep posting.
Pictures (if availible) would be great.
THANKS
Roger
THANKS
Roger
My Feedback: (16)
GA
RE: Frequency Board
Roger,
Try Cool Pins
http://www.coolpins.net/
I think they are local to Metro Atlanta.
THe boards pictured are clubs I either belonged to or have visited.
Try Cool Pins
ORIGINAL: ROGER RUSSELL
IN
MT
RE: Frequency Board
Here’s an enclosed board. Obviously not commercially made though.
http://hollycloudhoppers.org/newsletters.html Go to the 2006 Spring newsletter and page 7
RE: Frequency Board
At our club we have a 8"x36" piece of aluminum with
all the frequency numbers on it. In the same general area
we have some clothes pins. You want a channel , put a pin
on it,when your done take it off. Has worked well for many years.
Simple is best. You can have all the fancy impounds combined
with the freq board but the weakest link in the chain is still the
person.
Regards,
Roby
person.
Regards,
Roby
RE: Frequency Board
This probably does not help but it may be a low cost solution till you come up with the high priced approach.
We can't put up any permanent structures so our fequncy pole is made from door/floor molding that costs about $.30 a foot and comes painted white. Then we mark off with a sharpie and write in the numbers. Clothes pins are used to designate channels in use.
A tube is attached to the pole with plumbing strap. We put a headless spike in the ground and slide the pole over it. The same approach could be used by hanging the piece sideways. Total cost about $12.
DE
RE: Frequency Board
ORIGINAL: Red Scholefield
I like this simple system. Do you find that wasps build nests inside of the PVC tubes? Or, don't wasp like PVC?
Brian
