Magic Extra Radio Installation
My Feedback: (14)
PA
The plane was a snap to build although I made a few changes such as cable pull-pull rudder, 2-56 rods, and metal clevises but I'm not sure how to install the receiver and battery pack. I'm using a 600 maH flat pack and a really small Hitec 555 receiver but there doesn't seem to be anywhere that I can install the receiver and battery pack when it is wrapped in some foam.
How did you Magic Extra flyer's install your flight pack?
WV
I couldn't use foam on mine....it was impossible to fit......I velcroed them to the fuse in that small compartment towards the rear of where the wing mounts.....the battery is closer to the front, and the receiver is behind it.....
Mike
Mike
