Good first biplane?
Moderator
Good first biplane?
I've been flying for a few years, I like giant scale gas planes mostly. I'm not into fancy aerobatics or 3D flight, but I like the way sport planes handle. I've always flown single wing planes, Extra 300s and things. I want to get the Hanger 9 100cc Beast, but I want to get a feel for biplanes first.
What do you guys recommend as a good medium sized electric biplane to mess around with? An ARF or Spektrum BNF would be best.
RE: Good first biplane?
A Skybolt is a GREAT medium sized introduction into bi-planes.
It does not fully exhibit the "stop on a dime" response to throttling off, and as biplanes go, has a pretty decent glide.
The long wings and tail give it more stability while keeping a biplane's typical aerobatic capabilities.
My first biplane was the 40 sized Ultimate from Airborne Models and before it, my most advanced plane was a 40 sized Cub. You should have no problem. It would lend its self to be a good canadate for electric power but I flew mine with an OS .50sx.
Moderator
The skybolt looks good. What about Eflite Pitts 15e?
http://www.horizonhobby.com/Products...ProdID=EFL2550
And not what I would classify as "medium sized", especially compared to a 100cc plane.
Even a .40 Ultimate falls into a "small" boardering on "medium" catagory.
I had the Pitts M-12. It is definitely an exciting plane, but it made my heart pound when I flew it! You really have to be on the sticks! The Pitts will tend to fall out of a turn if you slow down too much.
I also had the E-flite Rhapsody. This bipe is much more tame than the Pitts, and a bit bigger. With the Power 32 motor and a 4S LiPo, she scoots along very quick, but slows nicely for landings.
But, if you're looking for something larger, a Skybolt is an excellent choice!
Moderator
Hmm the Rhapsody does look good. I want electric for my "introductory" biplane since I have tons of motors and ESCs lying around.
The Sebart Miss Wind is a nice electric Bipe. It's a 50e class and uses 6S LiPo Packs.
It's a pattern plane that can 3D so you can set it up from mild to almost wild.
The Great Planes Reactor 61 would also be a good choice.
The Super Skybolt exhibits exactly the flying qualities you are seeking. It's a fantastic plane but is not really ideal for electric conversion.
Personally, if you are truly serious about progressing to a Beast 100cc then i would forget about electric for this "transition" choice and go with a small gas engine so you can get a feel for them too. A 100cc gasser is not the ideal way to learn about gas engines.
A Skybolt with an NGH 17cc or DLE 20 would be a good stepping stone.
Come to think of it, The Reactor .61 is a GP/EP model so you could start off with electric and convert it to gas later on. The NGH would fit well. I've seen DLE 20's crammed in there but it's ugly.
I had an eflite Pitts 15e. On a normal turn to line up for a landing at about 1/2 throttle, both the left wings folded up. Flew nice. Not built nice. Avoid it.
Yup, stay away from the Pitts, it is NOT a good first biplane.
I learned that the hard way when I got my first even though I was very proficient with aerobatic and 3D planes at the time.
A smaller sized plane such as a .15 size or below, is even less suitable.
The Ultimates are nice, but landings will be "different" than what you may be used to.
The Skybolt, Aeromaster and Waco all have better glide capabilities and longer tails making them better suited for a first time foray into biplanes.
CA
If you're into WWl planes, I would highly recommend a H9 Sopwith Camel. Very easy to fly as long as you take off and land into the wind. I get comments from others at the field every time I fly as to how beautiful the plane flies and how big a smile I have on my face.
Harry
Harry
