Nexstar wing troubles
Idid the usual forum search and found nothing. Has anyone encountered a problem getting the wings on theirs to slide together properly?
RE: Nexstar wing troubles
Jeff,
I don't know what to tell you... Call Hobbico service and they'll help.. They may give you a return permission number. Then you can return the wing halves and it'll be their problem. They will probably send you a new wing.. They're good that way..
Jim Gallagher
Jim Gallagher
Mine slid together fine but I had a terrible time trying to get it onto the plane the first time ...I had to sharpen the bolt and elongate the hole...After it has been on once it is fine though...Is the steel wing joiner rod what is stoping it? Maybe to long or somthing in the wing hanging up???Take the rod out and try to see if the wing goes together...
Update. The new wing joiner helped but the hold down bolt had to be sharpened and the hole elongated to fit. Iguess I expect more than this from GP. Beautiful looking plane otherwise.
Oh and the holes for the pushrods where they exited the fuse at the rear had to be elongated slightly because of drag issues.
I rember that on mine too...The Push rods were a bit tight at first... Glad you got your wing sorted out...You will have lots of fun with that plane , at least I did with mine..What motor are you using? I used an OS46 and it was a perfect match...Watch the cross wind take offs. They can be a bit hairy...Also it likes to drag its tail in the turns so to make a nice looking turn you need to use your rudder. Thats okay because it a good thing to learn to use your rudder anyway...The sooner you get rid of the crap on the wings the better...It flys better with out that stuff. Plus the auto pilot thing is nothing but a problem fighting you to fly. I would ditch it rite off the bat...If you dont know how to fly better to get an instructor to buddy box you for a few flights and if you do know how to fly you dont need it anyway ...Good luck... Keep us posted please
Iam an experienced pilot, this is my sons plane. I have removed the flight aids he will be fine with a clean airframe.
He has a lot of talent and some stick time with one of my other planes.
I too am thinking of using an OS46, probably and FXI will pick up from my buddy Bruce Fischer at brucercengines.com, Ihave gotten several from him and they were all awesome, he tests all his engines before selling them.
The engine mount restricts the number of engines you are able to use with the vibration isolators, my Irvines wont slip in or Icould use my well worn 46 on it.
We ended up using a really sweet Thunder Tiger 46 Pro on the Nexstar (the 46 FX Ichose had a liner problem, go figure, and Bruce was great about standing behind it).
It went together without too much hassle despite the stock mount giving me a few fits.
It took 1.5 OZ of lead to balance it, wish it hadnt but it is still a pretty light airplane for its size. Cant wait to see how it performs with just a 46, seems like a really big plane for such a small engine, but then again I have been flying my GP Escapade a lot and its a tiny plane with a big engine.
I also thought this was too big of a plane for a .46 but I have an Evolution .46 in mine and it's just about perfect. Plenty of get up & go when I need it. Flies great and definitely serves the intended purpose. I have 20+ flights on mine and am really eyeballing that Pulse XT 60 I have on the build table!
If this plane doesnt suffer from too many prop strikes Imay consider a big 4 stroke , then Iwould use a 12" prop. Ihate using a big prop on a tricycle plane since my landings usually suck pretty bad .
On my last 2 trainer type planes Iended up using 10" props until Iconverted the last one to a tail dragger (it died recently due to a radio failure).
Ibet my Enya 60 four stroke would be a great engine on this plane. Its a big heavy powerful 4S, if the ground clearance isnt an issue for a 12" prop.
Ido fly off grass a lot of the time and the local field is pretty rough. The next closest field is excellent and wouldnt be a problem except for the hour drive and resulting transportation costs.
