p51 pts balancing question
i have the new p51 pts. i have to add at least 3 oz. to the tail to balance. what are other doing to balance it or am i doing something wrong. i would think it would be close to balance from factory.
My Feedback: (12)
CA
RE: p51 pts balancing question
a slightly nose down attitude when balancing is a good thing
will give you an easier flying aircraft
or can you move the electronics around?
try moving the batt flat against the fuel tank bulkhead
I switched the placement battery pack and the receiver and it fixed my CG problem. I sat and talked with a guy who has been flying for 40 yrs. I was asking the same thing. That’s what he told me to do and it worked. He said add weights only as a last resort.
O one more thing blue locktite everything you can on the engine.
just wondering is this plane a good plane i have read alot about it but is it worth the money? i have wanted a p-51 but never wanted to build one. plus id like something i can do some spins etc with. just wondering need something to fly while building my other plane. and after since i wont do spins with my other one ( F-18).
thanks
thanks
Its a very good plane! I had mine for 5 flights, then crashed it. If they had an ARF I would buy it in a heartbeat. Its very stable, predictable and when your ready manueverable!
-Mike
-Mike
MB, CANADA
Sorry you lost your p 51, was all the training stuff off when doing aerobatics? I was told by a club member not to do any aerobatics stuff till all the trainer stuff is removed?? that was after he took it up for a try. He has more experience than I and flies just about anything, so I took his advise, when I remove them I will try some aerobatics.
roltech
roltech
