Hangar 9 1/4 Scale Piper Cub ARF???
#1251
RE: Hangar 9 1/4 Scale Piper Cub ARF???
ORIGINAL: GalenB
Can someone provide a link to the O-ring mod for the gear?
TIA!
TIA!
#1259
I am building this plane for for our local children's hospital. We have a Wings for KIds Air Show every June and we have raised $118,400 to date for the hospital. The hospital purchased this plane for our club to fly and display to raise money for the hospital. But I digress...
I tell you this because the servos were donated. They are the recommended Spektrum DS 821 servos. I fly Futaba and typically use Futaba and Hitec servos. As I began to cut the extra arms off of the Spektrum servo arms they seemed to be more brittle than what I was used to with Futaba or Hitec. I therefore purchased the DuBro HD Spektrum/JR servo arms and used those.
I don't know that there is any evidence that the standard arms would not work just fine...I just made the change primarily based on the size and ownership of the plane. I have put a donated 30cc engine on the plane so I feel the ounce of prevention is warranted. If the plane were to always be flown in a scale manner then standard arms again would probably be fine. This plane will be flown in air shows and demonstrations and will probably be flown beyond the scale parameters of the full scale cub. The reason for this will be to show off the modified graphics being added to the plane.
Hope this helps a little.
#1260
Finally got some time to work on the Cub again...it's ready to fly now...vacation starts Monday so I will maiden her then
Took some ideas from you guys and others for cockpit detailing...here are some pics
#1261
My Feedback: (75)
NY
Hi Bob,
How did your CG come out, I'm going to be installing the same power package as you and I am wondering if you had to add any addition weight for balance. Plane looks great by the way, Good Luck with the maiden
Gary
Gary
#1262
Thanks for the compliment...it's a little nose heavy ATM but that will be fine for the maiden...I like my planes a little nose heavy anyway
#1264
ORIGINAL: Bob dunlop
W/all that awesome cabin detail a nice, detailed, scale Continental sticking out the sides of the cowl would make you Cub even more impressive.
#1265
Wow! Thank you so much for that link....I was just sitting here wondering what to do about an engine..I'm all over this!
Thanks again,Bob
Thanks again,Bob
#1266
Thanks again,Bob
Thanks again,Bob
Here's the pdf file for the assembly manual.
http://www.topnotchkits.com/index_fi...bly_Manual.pdf
I'm going to get one of these in 1/5 scale for the World Models J-3 I just ordered.
#1269
Thanks Cannonball!...I just ordered the dummy engine and a new cowl to put it in...I'll post pics of the build
Did you order the Top Notch dummy engine kit?
#1271
ORIGINAL: SrTelemaster150
Yep
Yep
Cool, let us know how it goes.
I want to get the 1/5 scale for my World Models Cub.
#1273
For those using the DLE-20, how much and what parts of cowling are you cutting away for cooling? I've run a gallon through mine in the air without the cowling for break-in. Iput the cowling on and it overheated after about 10 minutes of low power cruising around. Ihad only cut a 3 inch long gap for spark plug on bottom, opened the square airbox and opened the aft side of the the false cylinder baffling.
Icame home and enlarged the two holes above the airbox and opened a large triangle on the bottom. Ihope this is enough. Iwant to preserve as much cowling as possible. It doesn't help that it was 90F today.
#1274
ORIGINAL: hidaven
Anyone find a 12mm prop nut or spinner? This bare nut looks like junk! : (((
Bob
#1275
ORIGINAL: BlitzPig
