RE: CMPro Extra 330L 50 size
Hello, how much throw does your elevator have? thanks.
Hi all , I maidened my version 2 of the extra yesterday.
I made some drooped wing tips out of block balsa that added 100mm to the wing span & fitted up my RCV91cd engine for power. Only had to use the 4.8V battery pack on the engine mount to balance at 85mm. Take off was VERY FAST at half throttle & it required three clicks of down elevator for thumbs free level flight. After a low pass I went verticle at full throttle & Whoow, the climb was out of sight and actually ended up in a hover, hanging on the Prop so it is possible to get this thing in a hover however it didn,t have the power to pull out of the hover so I had to drop out & she didn't like that, luckily I had plenty of height to recover. I misjudged the approach speed on the landing & I ended up coming in alittle to hot & ended up tipping on her back further down the strip. A couple of light scratches on the top of the cowl & rudder was all the damage , but the way the RCV hauled her around esp in the verticle suprised/shocked all of us ,all in all very very impressed & she flew very straight and true with the 2% down & right thrust of the engine. All up weight came out at 3500g not to bad considering the weight of the 91cd ,just hope she doesn't quit in the air on me , even with the extra 100mm wing span I dont think she glide very well !!.:D All the best Steff. |
hi...guys...
i had my extra's elevator up mixed with down flapron for final landing approach. this really help to avoid the tip stall. just want to know if anyone else has the same setting for their cmp extra330. |
1 Attachment(s)
Something we all probably have to do at some stage in this great hobby of ours REPAIRS !.I had a bad landing experience yesterday , came in way to fast & didn't bleed the speed off in time ,then had a mental episode & botched the flair ( as in NO FLAIR ) SHE BOUNCED & THEN DROPPED A WING, managed to get the wings level before she hit again but one wing tip dug in & over she went.
a little damage to the top of the rudder some scratches on the cowl & canopy and messed up one of my drooped wing tips. So out with the tools & iron & now we are back to flying status. I have to say the RCV91cd is a great engine combo for this plane ,more power than you require , A am flying around half throttle most of the time but when you want to go verticle or throw her around it's nice to have all that power there, & high speed low passes [X(]. Steff. |
hi...PSJDBF....glad to see some one still flying this air craft... May I ask what is your propller size and the RPM with RCV91cd. BTW, the dropped win tip is cool. I got get a set of them to make my win longer..
1 Attachment(s)
Hi,
I've had one of these CMPro Extras for about 3 years now and I like it. I've always had it balanced just in front of the Fibreglass spar, I have recently redone the cockpit and I also still run an OS 61 FSR (About 25 years old engine) which is more than enough grunt for normal aero's, I'm not very good at 3D stuff... |
Does anybody know where I can purchase a replacement canopy? Ak-models doesn't sell replacements and Nitro planes is out of stock and don't know when they will be getting any in.
Thanks! Mark |
ORIGINAL: mallen Does anybody know where I can purchase a replacement canopy? Ak-models doesn't sell replacements and Nitro planes is out of stock and don't know when they will be getting any in. Thanks! Mark Try this one it might get you close enough. http://www3.towerhobbies.com/cgi-bin...?&I=LXWMW9&P=7 |
ORIGINAL: mallen Does anybody know where I can purchase a replacement canopy? Ak-models doesn't sell replacements and Nitro planes is out of stock and don't know when they will be getting any in. Thanks! Mark There are usually different things that can be done. One easy suggestion: If it's fractured or even cracked, tape the pieces in place from the top, using masking tape, trying to retain the original form. Apply CA to glue the fractured pieces back together carefully. Then you could optionally apply fiberglass and epoxy on the inside to make the canopy stronger, finally lightly sand and prime the outside a dark color. If you want to presever the transparency and the cracks are not too bad, I've resorted to the first steps, then I apply striping tape to hide the cracks, by making the striping appear to be part of the canopy itself.... e.g. establishing symetrical stripes.... etc. You can also often get a canopy for a similiar but different plane ( preferably something larger ) and using a heat gun form it to your plane... but this takes some experience to get it right. |
I have a spare canopy ,it has a few scratches on the top (not that noticable though ) if your interested PM me & we can discuss postage & price.
Steff;). |
1 Attachment(s)
Just got home & had a look & the canopy is new & has not been used because I used the old canopy on the new extra, see pic,s.
Also have put some cessna gear/struts on her to see how she lands with a wider track, so far seems to work fine. Also included a link to a vid I put on utube with the first one that I lost & the replacement, dont think I have posted it on this forum yet ?. All the best Steff. http://www.youtube.com/watch?v=vybM6GZqv9M |
Hi all
just finished building the cmpro would this fly with a OS 46 LA think will have to add quite a bit of nose weight |
ORIGINAL: rcbuff2001 Hi all just finished building the cmpro would this fly with a OS 46 LA think will have to add quite a bit of nose weight I would also add epoxy to all of the internal structures to reinforce those, along with their adhesion to the plastic. - Ooops I responded to the wrong thread! I was talking about the EP extra... my bad! |
My recomendation would be a 60 sized 2 Stroke, the 46 may be a little underpowered.
That's true it will be underpowered ! You may be disappointed and you will have to put a lot of lead.
Previously i put a 55ax and it wasn't enough for my side ; not enough fun ! Then with a 70surpass aerobatics were far much better ! |
dose any one have a PDF file of this model? thanks.
I can scan the instruction manual & e-mail it to you if you want ?.;)
A Vid of mine with streamers ! http://www.youtube.com/watch?v=aZvKPRUE-Rw |
What size Spinner is best for the Aircraft?
Will get back to you on that one soon ,my plane is stored at a mates place & cant remember the spinner size, I will get around there & check it out soon & let you know.
Cheers Steff. EDIT ... just measured mine which was 58mm or 2 1/4'' I've used 3 different spinners all of this size. |
Thanks 21/4 .................. </p> |
<p class="MsoNormal" style="MARGIN: 0in 0in 0pt; tab-stops: 170.25pt"><span style="FONT-FAMILY: Arial; FONT-SIZE: 18pt; mso-font-kerning: 16.0pt; mso-bidi-font-weight: bold">I was wondering what would be a better power plant for this aircraft. An ASP61A 2 cycle or a ASP FS80AR 4 cycle.
</p></span></p> |
.</p> |
<div align="left"><pre _fckxhtmljob="1" style="TEXT-ALIGN: left"><span _fckxhtmljob="1" style="FONT-SIZE: medium"><span _fckxhtmljob="1" style="FONT-FAMILY: Arial"><b _fckxhtmljob="1">Well I got all the parts and goodies together. [/b]<b _fckxhtmljob="1">I have an ASP61A for a power plant.
[/b]<b _fckxhtmljob="1">With a Bisson pitts mufflerA 2.25 inch Aluminum spinner from NitroPlanes. [/b]<b _fckxhtmljob="1">I’m going to try Power HD servo’s, four Power HD 1501MG’s or the control surfaces and a Power HD 1160A mini for the throttle. [/b]<b _fckxhtmljob="1">use a Hobbico Hydrimax Ultra NiMH 6V 2000mAh flat receiver battery pack. With a Airtronics 8-Channel RDS8000 radio..........[/b]</span></span> </pre></div> |
all the best for the maiden !:D.
