SuperBrain 969 Pro---Help!!
PA
I purchased a SuperBrain 969 Pro as my primary battery charger becaue it will charge NICD, NIMH and LIPOLY. However, it will not charge any battery that does not register a voltage reading. I purchased LiPOLY from Ikarus to fly my helicopter, but cannot charge it. How can I get a minimum charge into the battery so I can then put it on the SuperBrain?
Frustrated,
Pikebalder
Frustrated,
Pikebalder
OR
Are you sure there is not a problem with the battery itself?
Most chargers know if the circuit is open or close. If your charger is telling you "no battery" etc then it probably means there is a break in the circiut or a problem with the cells themselves.
Lipoly have very thin tabs that can easily break.
I would contact the vendor you purchased them from and ask what they think.
Just my .02
Mike
Just my .02
Mike
