Go Back  RCU Forums > Radios, Batteries, Clubhouse and more > Batteries & Chargers
Reload this Page >
want to get a 969 superbrain pro
Batteries & Chargers Nicads, Nickel Metal Hydride, Lithium, LiPoly, Chargers, Cyclers, etc...
Old 08-13-2003, 02:53 PM
electricfan
electricfan's Avatar
Default want to get a 969 superbrain pro
i want to get a 969. its what ive been looking for forever and its very versatile. ive got some questions before i buy. how many lipoly cells will it charge, and how long would it take to charge a 1200 mAh lipoly battery? and everywhere i look theyre on backorder. does anyone know any good places to get one online?
Old 08-14-2003, 08:46 PM
samadama
Hello,
I just ordered mine at Tower hobbies and I am sorry but I can't help you with your other questions.
GoodLuck
Old 08-16-2003, 08:35 AM
Jimmy Bananas
My Feedback: (13)
Default charger
I just bought mine yesterday at my LHS....$104.95...looks good..haven't tired it yet....good to try it today...A little confusing,but will sit down and study the instructions...my entire fleet is made up of NIMH 1650ma batteries..thats all I use now...will give you the skinny as soon as I know how to work it......
Old 08-16-2003, 03:35 PM
Ed
How many outputs ?
Old 08-16-2003, 04:06 PM
Jimmy Bananas
My Feedback: (13)
Default Charger
GeeBeeJim:
It has two out puts...can charge 2 batteries at once or one rec'r battery and one transmitter battery..On the side there is a place to hook up an adapter (which is furnished) to charge your 12 v field box battery..pretty nice unit....check it out
Old 08-16-2003, 09:39 PM
d_wheel
d_wheel's Avatar
What cell count and amp rating does it have for LiPol packs?
Later;
D.W.
Old 08-17-2003, 12:53 AM
electricfan
i decided not to get it because i dont really need it. i asked mrc and they said it can charge up to 3 lipoly cells, and it would charge a 1200 in a 1/2 hour
Old 08-17-2003, 11:52 AM
cchs1964
Does the 969 have a trickle charge feature and if so is it adjustable?
Jerry
Old 08-17-2003, 12:16 PM
Jimmy Bananas
My Feedback: (13)
Default Charger
cchs1964:
The picture shows a trickle charge,but will give you the info that is in the instructions in regards to this: Quote..
# 13:
When in the fast charge/discharge cycle is complete,the unit will beep once and the word "stop" will blink on the screen. At this time,you can scroll through the displays to check the finishing valves mentioned about such as time (min) and the capacity (mAH). If in the charge mode,a 50-minute 50~80 mA trickle charge will begin.After the trickle cycle, the charger will automatically go into sleep mode. Press the stop-start button to reset the charger.
This is the best I can do to answer your question..............
Old 08-17-2003, 12:21 PM
cchs1964
Jimmy,
Thanks for the info...the ad did not reference anything to trickle charging.
I am going to order one through Road Rage Hobbies...$91.50, free shipping in USA.
Thanks again...
Jerry
Old 08-18-2003, 03:18 AM
Ed
Does it discharge cycle too ?
I don't see any readout display in picture ?
Old 08-18-2003, 04:09 AM
Jimmy Bananas
My Feedback: (13)
Default Charger
GeeBeeJim:
According to the instructions,yes it do. It's on page 6.....
Old 08-18-2003, 06:07 PM
electricfan
they have a pdf instruction manual on their site- modelrec.com
Old 08-27-2003, 04:55 AM
Borzak
I got mine in today. So far it seems pretty good. I discharged a few packs and charged some more.
The few things I really don't care for are...
1. On channel A is a set of bannana plugs - good. On channel B is a male TAM connector - bad. I cut it off but it was still a pain and it's almost impossible to find female bannana inline connectors (not post type) to fit the other 4 adapters I have that are male bannna plugs (that I don't want to change because they also fit other chargers and channel A).
2. There's no way to store pre-sets at all. Every time you charge a batter you have to go thru the menu and change things like peak sensitivy in mV EVERY TIME - as it's always too low for a NiCAD charge.
Other than that it's seems to be pretty good. I charged a 600 mAh receiver pack at 1200 mAh rate on channel A and a 2000 mAh pack at 4amps at the same time off my 12volt field batter and it worked fine.
Plus it comes with a 120volt to 12volt adapter (up to 5 amps) which is nice.
Old 08-27-2003, 09:46 AM
roger- Michigan
roger- Michigan's Avatar
Yep. I purchased one and once I looked at the owners manual, I sent it back. I didn't realize how lucky I was already owning a GP Triton.
No memory on your settings, so every time you have to enter your preferences. the "b" output with wires, only being able to discharge on "A". And there is no "discharge-to-charge" cycle as on the triton, where I can set it to discharge knowing when I come back it will be fully charged.
Triton is the way to go -- at least between these two. I just ordered my second. I also just purchased a Hobbico quick field charger (with two outputs) so I could use it while park flying..
Roger
Old 08-27-2003, 11:52 AM
cchs1964
When choosing between the three modes to charge from, peak sensitivity, time, and capacity, how do you choose the one mode you want. e.g. If I want to use peak sensitivity do I scroll to the value on the LCD and then hit start?
