turnigy nanotec batteries?
hey guys i was wondering how true is this battery nanotec batteries 6s 60c 5000mah its supposed to be 300amps.whos tried nanotec batteries period i want to hear all experiences with nanotec batteries especially in high amp draw set ups i would to hear from heli guys too who push the limits of every batteries.sooooo lets hear it guys
My Feedback: (325)
RE: turnigy nanotec batteries?
I have no experience with the specific packs , but do have some other nanos. I'm going to guess they are about 30C packs. I'm soon going to test some 2.2 nano packs to their max current. I expect that they will have their actual ratings cut in half as well. You may also search for them in the batterygraphvault. Maybe someone has tested them.
TN
I received 2 ea. Nano-Tech batteries from HK. 2650, 4S, 25C-50C . One of them will not take a charge, Can't get it above 15.2 volts. This is a brand new battery , never put into service. Naturally they will not warranty it.
My Feedback: (325)
ORIGINAL: anunaki
good info wheres the battery graph located?also you are basicly saying they over rate these nanotec lipos right bud?
Most lipos on the market were and still are over-rated. Of all the packs I've bought the average seems to be an actual rating around half of the label rating.
FL
ORIGINAL: cutaway
300A? That number can't possibly be right. You need to cable it with 250mcm wire as big as your thumb.
MB, CANADA
My Feedback: (325)
45 C is very impressive in my book , but either the packs weren't charged all the way OR should've went further (to at least 1800 mah)
A 65 C pack that can do even 32 C is pretty good. I'm still guessing that even the 2.25 pack is actually about 32 C at 150 deg F. Generally as the capacity goes up the difference between the actual rating and the label rating gets larger.
I doubt that 90% us will use a pack at 40C or higher anyways. [X(] I know I won't.
