ESC capabilities
ESC capabilities
I have a Turnigy Plush 12amp (2ABEC) BESC ESC that I am running a 500 mAH 3s 25C battery thru. Can I run a 2S, 500 mah battery thru it also? I am using a brushless 1300 Kv motor. Thanks
That's it. Another question.....the Turnigy motor came and there is a rubber O ring that is the diameter of the mounting holes on the back of the motor. Are these to be put around the mounting bolts as a shock device before tightening? Also, there is a hub like piece that looks as though it slides over the shaft to change the shaft size for a prop. I guess I am assuming a lot but the only electrics we have are RTF's. Any help is greatly appreciated.
