Dual battery hook up ?
My Feedback: (16)
TX
What is the best way to hook up 2 battery packs in my plane. I have 2 charge switches, and the batteries are 1600 NimH.
Should I just plug them both in the receiver (using for one an empty channel ), or should I use a Battery backer ? If I use an empty channel, do I have to disable that channel on the radio (I am using a JR 8103) ? I am new to dual packs, so I would like to make things right.
My Feedback: (16)
GA
As thomasb says, visit red's site.
Basically you want to hook both pack up through the switches and into open slots in your receiver. If you don't have any available slots then use a "Y" cable to get the power where needed
My Feedback: (16)
GA
C. L. "Red" Scholefield is "THE" battery expert in my opinion. There are many knowledgable people, but to me, he is the expert.
http://www.rcbatteryclinic.com/
Use this to connect 2 batteries. If 1 fails (e.g. dead cell) the voltage will remain stable (the good battery won't try to charge the bad one)... Make sure you use a schottky diode to prevent a voltage drop (user of normal diodes will make the voltage drop by about 0,7V. Using a dobbel schottky diode this will only be 0,3V).
Originally posted by Geistware
PieterMX,
That is the most simple circuit I have seen yet.
Do you have a part number for the dobbel schottky diode?
PieterMX,
Originally posted by Vince
Diodes are not needed, one battery will not discharge into the other without the diodes.
Vince
Vince
CA
... try it yourself ... they will
I think I would rather take this issue than use the schottky diodes. Here's my thoughts:
(1) Even if you use schottky diodes, you will see a 0.2V or higher v-drop under load at all times. Lower volts is not what I like to see.
(2) Two packs of the same voltage, regardless of capacity, will not "fight" each other when used in parallel.
(3) Charged cells rarely short -- this is an issue that tends to occur to packs that have low charge levels. I do not fly when my Rx packs are low.
(4) If a cell shorts, the increase in current is equal to about one or two active standard servos. Certainly not enough to cause immediate danger.
Folks, regardless of method you use to bridge two packs together, you should still check them with a ESV before each flight (or install two LED style V-monitors). Two on/off switches will allow you to do so.
PieterMX,
You need to take a look at this topic (Parallel Operation = Reliability & More Flight Time ) under Reds RC Battery Clinic. It explans why there is no need for the Diode.
Randy
Randy
Vince
NM
Try to avoid the "Y" connector that someone suggested up above, and use one of the unused receiver channels.
By "Y" connecting parallel packs, you re-introduce the "single point failure mode" potential, thereby eliminating full redundancy.
Use the FULLY REDUNDANT system that Red describes in his clinic.
No diodes, just common sense.
And no, you don't have to de-program the spare channel that you plug into.
Jim, so what you're saying is that by using a "Y" to connect to a single port on the receiver, the actual port on the receiver could go bad?
Randy
Randy
FL
Blackie, not to speak for Jim, but...
No, using a Y will not cause the port to go bad. Rather, if you put your redundant batteries and redundant switches through one wire by using a Y, IF that single port/wire goes bad, you're toast, so you've in essense lost a bit of your redundancy.
It is better to put the two separate batteries into two different ports on the receiver. If all channels are used, then Y one of the batteries into a servo lead, NOT the other battery lead.
- George
- George
NM
Randy
Randy
Stay with Reds FULLY REDUNDANT system described in his clinic ! I've been using it for years. It's simple and reliable; and the fewer connectors and electronic components that you have in the battery circuit, the more reliable that battery back-up circuit is going to be.
My Feedback: (16)
GA
Jim,
What I stated is as follows.
I would welcome an explanation on how to hook up a second pack when slots are not available on your receiver!?
Using Geistware's method I believe I would do away with the quick disconnects and just solder the Y to both switches leaving the one connector for the reciever. At least you would have a better connection on one end anyway.
Randy
Randy
FL
No one reads my posts :cry:
Geistware, just use a "Y" connector to connect your second pack with a servo lead. For example, you could Y a battery into your elevator lead on channel 2 and have another battery plugged into a receiver port directly. Both are on the same power bus!
- George
- George
Mulligan, can you please help me understand better of what you are illustrating.
How would the duel switch's be connected using your illustration?
*scratches head*
Edit in:
OK after more thought I believe what you are suggesting is use the normal hook up, but use an actual ready made y harness connect one end to say throttle servo lead coming from the servo the other to the switch lead that is coming from the switch and then the single end of the Y goes to throttle port?
Randy
*scratches head*
Edit in:
Randy
