Reload this Page >
DX7 dual rate
DX7 dual rate
Old 07-17-2012, 12:44 PM
goirish
goirish's Avatar
Default DX7 dual rate
My DX7 on certain models will not activate the dual rate. Rudder for example. I set the low rate at 50% then flip the rudder switch and set it to 100%. When I return the switch to the low rate it is not 100% This is only on some models. Is there a mix someplace that I am missing. Called Horizon Hobby but no return call yet.
Old 07-17-2012, 07:29 PM
tacx
tacx's Avatar
Default RE: DX7 dual rate
Not sure what you mean.
You say you "set the low at 50%, then flip the switch and set the high at 100%. When you flip back to low it's not at 100%."
It won't be 100%. Low will be 50%. ??
Old 07-18-2012, 02:26 AM
bingo field
bingo field's Avatar
I don't remember which model Tx it was, but I had a JR that was somewhat similar until I went in and reset the model settings for that specific model. I went through and wrote down all the settings that took before hand so I didn't have to reinvent the wheel to make it normal again. Once reset to defaults, I was successful in setting all my settings to where I was trying to take them. It appears that occasionally, the memory for a specific model slot takes a kind of scrambled bit pattern, and the only way to fix it is to do a reset on it. It makes you more proficient at flipping the switches and setting all the settings by having to do it more than once...
Old 07-18-2012, 07:07 AM
BarracudaHockey
BarracudaHockey's Avatar
ORIGINAL: tacx
You say you ''set the low at 50%, then flip the switch and set the high at 100%. When you flip back to low it's not at 100%.''
Glad I'm not the only one that read it that way
Old 07-18-2012, 07:44 AM
goirish
goirish's Avatar
the word should have been "now" instead of "not"
Old 07-18-2012, 08:45 AM
opjose
opjose's Avatar
I would perform the model reset indicated...
You MAY have to exit the setting before you flip the switch so that it will "take".
Old 07-18-2012, 08:49 AM
SeamusG
SeamusG's Avatar
To test your setting use the "servo monitor" function.
Old 07-18-2012, 11:54 AM
goirish
goirish's Avatar
Got it. It was a menu item that I had never used before. BTW, Odd that Horizon Hobby never returned my call. Not like them.
Old 07-18-2012, 07:18 PM
tacx
tacx's Avatar
ORIGINAL: goirish
the word should have been ''now'' instead of ''not''
Amazing how one little letter in a whole sentence has a completely different meaning.
Glad you figured it out.
Old 07-19-2012, 02:30 AM
goirish
goirish's Avatar
Boy!! it did change the meaning didn't it. I was once told, "the hardest thing in the world to do, is get a thought from one person's mind to another in the manner it which it was intended"
Old 07-19-2012, 05:44 AM
SeamusG
SeamusG's Avatar
Made so much more difficult when you cannot see their face (smile, frown, impartial, etc.).
Old 07-19-2012, 06:12 AM
DenverJayhawk
DenverJayhawk's Avatar
stupid question, but are you sure you have the low rate set to the same switch as the high rate?
Old 07-19-2012, 06:33 AM
goirish
goirish's Avatar
Yea, on the DX7 you have three switches, one for elev, kone for rudder and one for aileron. When you set the high rate (say aileron) then flip the switch you can set the low rate. Then go to another switch like the rudder and do the same thing.. There was a place in the menu that you could designate only rudder or aileron or elevator. The menu also allowed you to select all three. When I was having problems trying to do the dual rate. the menu was set only to aileron. Does this make any sense?
Old 07-19-2012, 06:36 AM
gjesion
Makes sense. The DX7 is set up to allow either one switch to set hi/low rates on all three surfaces, or to control them individually. A good thing IMO.
Regards,
Jerry
Old 07-19-2012, 06:38 AM
goirish
goirish's Avatar
Didn't know that until I started playing around with the menu.  I guess if all else fails, follow instructions.
Old 07-19-2012, 06:40 AM
SeamusG
SeamusG's Avatar
On my DX7 I use a single switch (common) to control dual rates for all controls - the aileron D/R switch. I use the rudder D/R switch for my throttle kill mix.
Old 07-19-2012, 06:43 AM
goirish
goirish's Avatar
Hummmm!!! didn't know you could do that. I like the idea of the throttle kill switch. I just use the throttle recovery now to shut down the nitro engine. I use a servo operated choke for my gassers and that is how I just shut them down.
Old 07-19-2012, 07:47 AM
SeamusG
SeamusG's Avatar
I would guess that you could use the same switch to activate the glow kill switch & the gas choke servo so that the flight line procedure would be exactly the same for all models.
The DX7 has a system menu (plane name stuff) and a function menu (D/R, mixing, all the good stuff). I think that you specify the common D/R at the system level. Check the manual.
Old 07-19-2012, 08:36 AM
DenverJayhawk
unless you really need rates setup on different switches, i would recommend putting all your surface's dual/triple rates onto one switch. It's much easier
Old 07-19-2012, 08:41 AM
opjose
opjose's Avatar
When maidening a plane, I prefer to keep the rate switches separate.
That way I can test each surface individually to obtain the best settings.
e.g. You may find the ailerons do not have enough travel, while the elevator is far too pitchy, etc.
Old 07-19-2012, 10:02 AM
goirish
goirish's Avatar
That is the way I like my set up to be.  Some times when I want to do a stall turn, I flip the switch for the rudder.  When I am on the ground taxiing I want the rudder on low rate.
Old 07-19-2012, 11:29 AM
DenverJayhawk
for me, when flying i forget which switch is assigned to which surface. So i set everything up on one switch. In reality, i probably don't need any dual or triple rate switches since i prefer to fly with high rates only.
Old 07-19-2012, 02:06 PM
carlospkf
I find the single switch method to work best. Also, it is a good idea to remember which switch you assigned. I spent an afternoon wondering why my P47 would roll so slowly even in high rates only to find that I was flipping the wrong switch in the transmitter.
Old 07-19-2012, 02:29 PM
goirish
goirish's Avatar
I don't believe that I have that problem as all of my planes are set up the same way. right hand side switch=rudder, right hand front switch=aileron and left hand front switch=elevator. All low rates are switches towards me, high rate is switches towards the plane
