Can I use Epoxy on A Foamie?
RE: Can I use Epoxy on A Foamie?
Yes! I broke my fuselage in half just behind the wings and glued it back together with 15 min epoxy. A few weeks later I broke it in half again. The joint that was epoxied held with the break being less than one inch away. I epoxied the second break and am still flying it.
IN
ORIGINAL: GRandolph
Epoxy is fine, but, depending on what you want to use it for, there are other alternatives. Uhu POR is great for Foam and "QUICK GRIP" EPP Foam Adhesive is great for EPP.
Both are available at your favorite Arts and Crafts store or you can order it from here: http://www.lightflite.com/
CGr
CGr
Thanks CGR for the link. An old dog can learn new tricks. I had no idea about the glue or the web site. That is why I enjoy the beginners forum. I learn something new just about every trip. Only been flying these things for fifty or so years. Figure what makes this such a great hobby. The more things change the more they stay the same. That same is the constant learning experience.
Yeah... they also make some pretty interesting light weight planes. I have two of the original "Bugs" that are pretty cool, but are very light and can be a handful in anything more than a slight wind... better indoors and are very well suited for indoor flying.
CGr.
CGr.
ORIGINAL: Mikecam
Many of us at the field use a hot glue gun. It's quick and works great, did I mention its quick.
CGr
My Feedback: (10)
Actually... I don't think my Flyzone FW109 has any foam left... I'm pretty sure it's a large block of 5 and 30 minute epoxy... flies great... Incidentally hitting tree's or buildings, any large obstacle really, no longer change the flight characteristics of that plane anymore.
ORIGINAL: bigedmustafa
Epoxy works good on foam, but use it sparingly. It can add noticeable amounts of weight and may impact flight performance on very lightweight planes.
I agree with bem. I built a small 3dfoamie, the plans called for 11oz AUW. I built it exactly to plans with recommended equipment, except I used epoxy to attatch the wings to fuse and on the carbon spar in the wing and they only called for thin and medium foam safe ca throughtout the build. My plane came out just shy of 13 oz AUW and it definately affected flight performance. I was using that plane to learn 3d maneuvers on. Well, I certainly learned something, when using epoxy go sparingly!
