first flight today!
RE: first flight today!
Based on everything that's been said, are you sure you extended your transmitter antenna before flight? It would explain:
- Why your morning flights went well but by afternoon you ran into problems (reached a point where you forgot to extend it).
- Why you're having the problem on take-off (at end of range with antenna down) but not on the bench.
- Why it went squirly but you were able to save it (at the threshold of reception).
ORIGINAL: flycatch
Just who is "slider buck" he joined in 2003 and this is the first post on anything. Taught himself to fly using a simulator only. Be skeptical and cautious with a person with no history.
+1 on all advice given.
ORIGINAL: jester_s1
I know you probably don't want to spend any more money, but a computerized charger will let you know for sure if your batteries are good. I see them frequently used on here for $30-$40, so it's not a huge investment. The ability to peak charge and do cycle testing tells you conclusively how good your batteries are instead of just guessing and hoping. There are considerably fewer unexplained losses of control talked about on the forums now than there were 8-10 years ago. Many would say that 2.4ghz radios are to thank for that, and I'm sure they are a factor. But about the same time those gained popularity, computerized chargers became a lot more commonplace. I actually think that has been a bigger factor, and RC pilots are finally making sure that their batteries are both charged fully and performing up to standard before taking off. Along with that, a $5 harbor Freight electrical multimeter will let you check voltages at your receiver and find problems before they cost you a plane.
i have a fluke meter where i could check the voltage before flying it. do they sell i meter like the one on the transmitters. the beeper that i bought from ebay will at least let me know now when the battery is getting low.
#31
ORIGINAL: flycatch
Just who is ''slider buck'' he joined in 2003 and this is the first post on anything. Taught himself to fly using a simulator only. Be skeptical and cautious with a person with no history.
i joined back in 03 when i was into rc cars. i sold them and im just now getting back into the rc scene. are you serious saying something like "be cautious"? what do you think im going to do? find out info on you and hunt you down or something..lol. sounds like you have some issues your self to be concerned about fella!
#32
ORIGINAL: fly24-7
yeah im positive that the antenna was extended. i even checked to make sure all the controls worked ok after i got it back on the ground.
#34
ORIGINAL: slider_buck
ORIGINAL: flycatch
#35
ORIGINAL: Lightspeed1551
Have you done a range check? There may be an issue with distance.
when i first flew it that morning i had my step dad there and we did a range check then. i kept the antenna collapsed and walked about 100' away and it worked perfectly fine. a couple hours later when i had the issue i was by myself and i didnt do a check.whats the best way to do a check if you are by yourself?
#36
My Feedback: (12)
Range check is done occasionally, you don't have to do it every time. 30 steps away is what is necessary. At that distance you can see the surfaces moving
#37
All good advice, butI would also suggest youbuy yourself a digital load tester and plug it in after charging and see how long it takes to drop the voltage to 4.8v A fully charged 4 cell battery should read about 5.8v fresh off the charger, if not you need a new battery or a new charger. Man you got lucky 2 times you lose control and got it backOne time would have been enough for me.
#38
It sounds like you are taking a lot of steps in the right direction. There is good advice here to follow.
Might I add that you look for a local club and RC coach to help you with some of these things. It sounds like you have a pretty good grasp on flying, but a coach would have things in his tool kit like a Expanded Scale Volt Meter and he would be able to check RX battery right there.
If you use the analogy of a picture is worth a thousand words - some well spent time with a coach/instructor is worth hundreds of those pictures (and posts on this Site)...
Good Luck - Keep flying..
#39
IL
Sounds to me like your receiver entered a fail safe condition for a moment and then returned control to you. Turn on your transmitter, then your receiver.......now turn off your transmitter. If your throttle closes and your ailerons move to a "rolling" position, you have figured out your problem.
#40
ORIGINAL: SharpProp
Sounds to me like your receiver entered a fail safe condition for a moment and then returned control to you. Turn on your transmitter, then your receiver.......now turn off your transmitter. If your throttle closes and your ailerons move to a ''rolling'' position, you have figured out your problem.
well i tried this and everything stayed in the same position it was in when i turned the transmitter off. dont think it has failsafe on it.
#41
ORIGINAL: raptureboy
All good advice, but I would also suggest you buy yourself a digital load tester and plug it in after charging and see how long it takes to drop the voltage to 4.8v A fully charged 4 cell battery should read about 5.8v fresh off the charger, if not you need a new battery or a new charger. Man you got lucky 2 times you lose control and got it back[img][/img] One time would have been enough for me.
yeah i know. i thought for sure it was a gonner when it did a 360 all on its own..lol.
#42
#43
what about this for a load tester?
http://www.ebay.com/itm/Hobbico-Digi...item2ec8b03f5e
#44
i took it out first thing this morning and had 5 excellent flights. i came home and decided to go back out to the same spot about 5 hours later.
All on the same day and no additional charging? and its most likely your flight pack was only a 6/7oo mah and had they received a full 14/16 hour initial charge as well as a simple charge just over night? You simply dumped your battery, that's what happened.
Forget the failsafe learn good charging practices for the type batteries you are using and yes the tester you linked is a good one and would work well for you
John
#45
so about how long on a single charge should i trust the receiver battery? when i did the 5 flights initially i was only in the air about a total of 30 minutes if that. i just had it out and had 3 more successful flights with no problems. well i did manage to bounce it into a chain link fence..lol. no damage though. still trying to get the hang of landing. real easy to come in to fast.
#46
why not have a extra battery charged up and get a field charger then u wont have to worry how many hours do you want to fly get a battey checker check you battery after each flight
#47
ORIGINAL: [email protected]
im going to order the one listed above. yeah i'll probably order me an extra battery also. trying to decide what batteries and charger to go with though.
#48
which charger do you guys think would be better to use?
http://www3.towerhobbies.com/cgi-bin...?&I=LXWTD9&P=7
http://www3.towerhobbies.com/cgi-bin...?&I=LXBMVP&P=7
#50
yeah thats alot nicer charger than what i was looking at. i went ahead and ordered the first charger and a 2000mah hobbico rx batter.
