RCU Forums - View Single Post - first flight today!
Old 07-02-2013 | 04:14 PM
  #32
slider_buck
Default RE: first flight today!
ORIGINAL: fly24-7
Based on everything that's been said, are you sure you extended your transmitter antenna before flight? It would explain:
- Why your morning flights went well but by afternoon you ran into problems (reached a point where you forgot to extend it).
- Why you're having the problem on take-off (at end of range with antenna down) but not on the bench.
- Why it went squirly but you were able to save it (at the threshold of reception).
yeah im positive that the antenna was extended. i even checked to make sure all the controls worked ok after i got it back on the ground.
