New user looking for help
Hello RC enthusiast's, This is a daft question but why does the steering and throttle work at same time?
Whenever I turn left the car wants to reverse throttle and turning right accelerates. Thanks in advance.
Not enough info to really analyze your problem. If your transmitter has the capability of mixing channels, I'd see if any mix has been programmed into the throttle.If your transmitter allows you to set each model to the "default stage", do that and then reprogram the servos for proper norm/reverse and any high/low rates you want.
