Setting fuel ratio on carby
Hi all..
can someone tell me an easy method of setting Rich/Lean ratios on a CX45 Enya engine.
What to listen for.
do i revv and peak RPM
What screw does what change?
I need to know a little about the setscrews and what they do.
2 setscrews -
1 on top near air intake.
1 on side near throttle barrel
any help appreciated.
thanks Marty
What to listen for.
2 setscrews -
thanks Marty
Marty get yourself to your local field. There is no set way to put the mixture screws to tune correctly. There are too many variables. If you go to the AMA website you can search for your local club.
NV
Google is your friend ...
https://www.google.com/webhp?sourcei...irplane+engine
Not a "one off" customized hand holding tutorial, but with diligence, all will become clear.
