Reload this Page >
Electric motor question.
Old 05-12-2019, 02:05 PM
270win
My Feedback: (14)
Default Electric motor question.
I bought this Tomcat G46 motor to put on a PT40 I'm converting to electric. It came with zero instructions and I'm new to electrics. It has a compression collet and a bolt on prop mount. But how the heck does the bolt on prop mount go onto the motor?
Old 05-12-2019, 02:24 PM
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
You will either have to reposition the shaft if the motor is set up for shaft replacement or you can cut off the protruding shaft. Personally I would go with The collet prop driver as they tend to run a bit more true then the bolt on prop drivers.
Old 05-12-2019, 04:24 PM
270win
My Feedback: (14)
Can I use a spinner with the collet?
Old 05-12-2019, 06:07 PM
speedracerntrixie
My Feedback: (29)
I can't see why not. The 63mm outrunner that powers my pattern airplane uses the collet prop adapter. You may want to,post a picture of the collet.
Old 05-13-2019, 07:27 PM
jester_s1
Moderator
Could that prop adapter fit on the other end? I've seen outrunners set up that way with a shaft sticking out the back.
Old 05-13-2019, 11:53 PM
speedracerntrixie
My Feedback: (29)
Jester, I think the other end has wires coming out of it.
Old 05-21-2019, 05:53 PM
270win
My Feedback: (14)
So apparently that shaft is held in y two allen screws and is pressed into the motor. I used it with the compression collet today and it was flawless.
Old 05-21-2019, 11:27 PM
speedracerntrixie
My Feedback: (29)
Very happy to hear that!
