kadet ly-40 and the Easy Fuler
TX
I have an Kadet LT-40 and I was wondering if i could mount an easy fueler on the hatch that cover the fuel tank. The is plenty of room my only concern is that it will be mounted horizontal instead of vertical as i see in most pictures.
The EZ fuelers are good once you get them "broke in". The little rubber seal/spring that opens and closes the fuel valve is kinda tight when you first install it.
