Saito Twin / Propeller Question?
I have a Saito FA-90TS Flat twin. It starts and runs in a CLOCKWISE direction. Does this mean that I need a propeller with reverse pitch since most engines run counter clockwise?
thanks,
ckelloggjr
thanks,
ckelloggjr
RE: Saito Twin / Propeller Question?
Yes. From the front The manual clearly states clockwise. I have had it running on the bench. It seems to run OK, but the prop is blowing in my face as I face the prop. the air should flow back over the plane. As it is right now, it is not. It has a right hand thread. I am getting concerned.
VA
You only turn the prop clockwise (looking at the engine crankshaft ), by hand to the compression stroke. This is to get good momentum to start the engine COUNTERCLOCKWISE. I looked at the [link=http://www.horizonhobby.com/ProdInfo/Files/SAITO_Twin-Cylinder_Four-Stroke_Manual.pdf]manual[/link] and it says (step 6) to prime your engine turning the prop COUNTERCLOCKWISE 2-3 turns. Then (step 7) clockwise to the comp stroke. COUNTERCLOCKWISE is the direction you should start it and run. The manual is a bit misleading. Also the manual does not recomend any pusher props only standard props.
I worry because there's nothing to worry about! I really do appreciate all of your inputs. I am going to bnch test it again today running it CCW. We'll see. I am sure it will be OK too.
ckelloggjr
ckelloggjr
Thanks to everyone! I bench tested it starting it CCW... it ran like a champ. Now I have to wonder why the right cyl. runs 40-50 degrees hotter than the left???? Any thoughts?
ORIGINAL: ckelloggjr
The FA-90TS is NOT a 2 needle valve engine! It is a single carb, single needle valve engine. I fail to see what the compexity or simplicity of this equipment and/or my experience level has to do with anything. If I felt the need to defend my experience or abilities, I would say that I am very mechanically inclined and experienced.
The manual is written VERY poorly and leeds the reader to beleive that the engine runs CW. This and the other questions were honest, legitimate questions that I would have appreciated answers to, and perhaps someone will provide some. If not, I will get by.
One of the luxuries of face-to-face communication is voice inflection. We don't have this sense online, but I assure you my comments were not written in a dismissive or patronizing tone.
You're right, you can operate any engine you want - it's yours. Before you dismiss me as a dunce, please glance at this situation from my perspective. Every week I see somebody enter the hobby, get too ambitious, and exit in frustration. I don't want this to happen to you.
No problem. I apologize for my abruptness. I am building a Great Planes .60 Piper Cub. I have the engine mounted and the cowling fitted. It's pretty exciting. I have always been the type to go all the way the first time. Why "dabble" ya know? I thought having real jugs sticking through the cowling - instead of fakes - was the only way. Here is a couple of shots of her so far... I am learning VERY much as I go along. This forum has been one place I can turn for good info. I will be installing a Sullivan on-board glow system, etc..., etc... I had a (new) friend make me the motor mount at his machine shop. If you'd like I can send a few more pics.
TX
I may be way off base here, but doesn't more air come off of the left side of the prop disc than the right side? Maybe not by much, but isn't this the cause (or effect) of "P" factor?
