engine high speed needle not responding
My Feedback: (13)
Hi All:
I have an os46ax given to me by a friend. Took it to the field today, in my plane,and started it up. Started just fine, tried to adjust the hsn, but it would make no difference. Tried the pinch test, through the whole needle range, held the plane nose up, wanted to die in that position in various settings. Have never flown this engine, it is not a new engine. Can anyone tell me why I can't get a change with my needle adjustment? It sounded like it had plenty of power and transitioned really well, but as soon as I held the planes nose up, it wanted to die, couldn't do the pinch test either, did not speed up when I did this either. Could there be a leak?
thanks for your input. I know there is someone out there who has a solution.
Norm
Norm
RE: engine high speed needle not responding
there is some things to check, lines for leak, close the needle and re opened again...try to use a tach to get peak rpms and try again.
You might also look up the manual on the 'net. I bought the same engine. The old pros at our field said the same thing that you did. It turned out that the starting point for the AX was, maybe, 1 1/2 turns. They started tuning it at 4 or 5 turns...and never got down to 1 1/2 turns......They thought 4 or 5 turns was correct since since the FX was set that way. When we started all over with the factory settings, everything worked just fine. Rich
Just to go over the obvious.....
The HS needle settings for the most part manifest when the throttle is over 70% or so. To see the changes created by adjusting the high speed needle you need to run your engine at WOT.
I typically restrain my plane, run it up to WOT and adjust the needle while the engine is running.
Have you tried this?
