RCU Forums - View Single Post - engine high speed needle not responding
Old 09-17-2009 | 10:57 AM
opjose's Avatar
opjose
Default RE: engine high speed needle not responding
Just to go over the obvious.....
The HS needle settings for the most part manifest when the throttle is over 70% or so. To see the changes created by adjusting the high speed needle you need to run your engine at WOT.
I typically restrain my plane, run it up to WOT and adjust the needle while the engine is running.
Have you tried this?
