best plane for park 450 bl outrunner
Hello all
I have the above motor with 20a speedo and 3 cell lipo (1800mah). I am looking for a good trainer aircraft to put these electrics into that can be hand launched. I have flown a Thunderbolt but it was too much of a handful and crashed in spectacularly hence why I have the spare electrics.
I am so confused with the 1000's of planes out there, any advice would be greatly appreciated
MO
RE: best plane for park 450 bl outrunner
The Mini Ultra Stick flies wonderfully with the Park 450, it is a very well made ARF. Search the forums. especially the electric forums for other opinions.
If you set it up right and slow down the controls it flies very nicely.
When you use full power and large control travel it is capable of breathtaking aerobatics. You can see it here & other places on the net.
http://www.horizonhobby.com/Products...ProdID=EFL2250
You must find an good instructor to get comfortable flying a responsive aircraft or even a "trainer". Some time on a simulator would also be very beneficial. Teaching yourself is learning the hard way. Joining a local club is often a good way to find a good instructor pilot.
Best wishes
max-nix
Best wishes
max-nix
The GWS Slow Stick may be just the ticket, very stable and cheap, $21.00 from Tower Hobbies on this side of the pond with no power plant (they call it the glider version) Though for training purposes you may want consider using a 2S lipo at first.
Good luck,
Pete
Good luck,
Pete
