Jeti 70advance opto
My Feedback: (7)
AR
Jeti 70advance opto
Heres the problem I ran into..As I say,Ive got a Jeti70 Advance opto controller and I used the program card to set it up,worked great..Then I tryed changing the setings a few days later cuss I was not the way I wanted,tryed the program card again but when I put the prog card on there was no beep or nothing..Everthing seems to work cuss motor starts run and good throttle controll so is there a way to reset this??
Thank you
Thomas
Thank you
Thomas
My Feedback: (21)
RE: Jeti 70advance opto
Did you remember to connect a receiver battery to the programming card this time around? The Opto controller needs an external power source to program.
Also, is the motor connected? It won't beep without the motor.
My Feedback: (7)
AR
Matt
yes I did it just like thge first time but it wont reprogram or beep after connecting the battery to it..By useing the throttle lever I can set hart timming or brake off on controlleer only..
I dontn know but its a new program card and controller..
One point,mine is the Jeti70 advance 3P opto...Not the plus!Any help !!
Iam doing things rite Iam sure
Thank you
thomas
Thank you
thomas
