esc,battery,motor setup
hello ,newbie questioni have a tower pro 2408-21t brushless motor ,(1400kv i think) 6x4 prop and an 1800mah 20c 11.1vlipo battery ,just bits lying aroundplus a15c 1100 mah 11.1v battery which esc could i use for either one battery or the other ,i want to put them into an easystar foamy 55"wing span
TN
RE: esc,battery,motor setup
ORIGINAL: beanie man
hello ,newbie question i have a tower pro 2408-21t brushless motor ,(1400kv i think) 6x4 prop and an 1800mah 20c 11.1v lipo battery ,just bits lying around plus a 15c 1100 mah 11.1v battery which esc could i use for either one battery or the other ,i want to put them into an easystar foamy 55''wing span
On 3s that motor with a 6x4 shouldn't be drawing more than about 10A, so either battery is going to work... on an Easy Star you need weight in the nose anyway, so the 1800mAh pack would be best for balance and longer flight time. Any ESC rated at 12-15A would be adequate for your needs.
