spur gear and engine plate brace/genesis
Has anyone fitted this kit to an original genesis ,and with what results.It,s fitted as standard on LE.and Nemesis i think.
RE: spur gear and engine plate brace/genesis
As i'm in the U.K. i can't help you with sourcing it locally, but cen quote it as part no. GS097 on their site. I have ordered one,but i could be waiting forever with the way things are over here.
CA
The kit is used to insecure the spur gears from moving due to vibration. IT will fit any Genesis. On the older generation where the side plate wasnt modified, simply drill 2 holes and you can install it.
VA
I wear out pinion gears every 5 or 6 tanks of fuel. I have tried a tight gear mesh but it doesn't seem to make a difference. Will this brace help with this problem? If so, does anyone know where it can be purchased. I can't find it on any online site.
Steve
Steve
Are there any other options for ratios wiith the Genesis spur gears, other than the stock 43T and 39T?
If so, does anyone have the part number/s?
VA
ORIGINAL: poor judgement
Steve
