RodneyFord , 09-17-2018 12:46 PM
It is surprising to me that there is no plans for Hanno Prettner's Calypso out there on the net. I built a few way back when they were current, modeled on the Model Tech kit. So I thought I would work up a set of drawings from the available information. There are still a few of the Model Tech Calyso's around so getting dimensions is possible.
RodneyFord , 09-17-2018 12:50 PM
Here are the kit instructions. They have a drawing of sorts included, so that is a good start. Not sure how accurate they are though so need checking against the real thing.
RodneyFord , 09-17-2018 01:14 PM
Here I have scaled and stitched together the Kit drawings also used Barry's info. I know the fin is not right as I have conflicting information.
RodneyFord , 09-17-2018 02:59 PM
The various fin dimensions don't quite stack up there is a 12mm or so discrepancy.
Rudder numbers look good here.
Barry's fin drawing has got the rudder a bit off but the rest looks plausible
Rudder is 11mm too long so either Barry's drawing is wrong or the kit one is wrong. Hard to know.
Picture of David Oxilia's build.
RodneyFord , 09-19-2018 09:20 PM
Mostly worked out the drawing. It would be great for someone with an original to check it. I will then tidy it up.
Fuselage and formers
RodneyFord , 09-19-2018 09:26 PM
Here is the DXF file. Sorry. was wrong file type. This one is correct
Hi Rodney
For some reason None of my cad programs will read your file, can you save it in a different format that is more compatible with older software Eg autoskech or as a PDF
Regards
John Papandreou
Regards
John Papandreou
RodneyFord , 09-20-2018 11:53 AM
I would be interested to know what the wing tip airfoil thickness is. With the root looking to be 14% I would think the tip should be 12 to 13%.
Hi Rodney
I was able to view the pdf... There are a few small issues with the plan that you may like to update
Paper Size Please make sure the Width of the plan is only 36 inches:- as this is the max paper size on a plotter the paper is on a roll therefore length can be what ever you like, . This will make Printing the plan easy,,,,We all want get a print made.so we can build one
Line Thickness on the drawing, you need to mage the lines a little thicker and all of them black, I know color looks nice but outputting is is a issue for some Plotters (Mine is a old HP 755cm)
Put a border around your plan with a scale on it so you can check the plot is correct.
Wood and sizes:- you need add these
Allow for the sheeting thickness on the foam wing and stab
I hope my feedback is help full and you have done a great job
last Put your name on it you have done a good job (My Tech Drawing Teacher would always insist on it)
Regards
John Papandreou
Regards
John Papandreou
RodneyFord , 09-20-2018 06:21 PM
That's great John. Work in progress. I haven't really wanted to produce a finished drawing yet as some of the dimensions are speculative. However until someone can check it I can not move further ahead. Sooo I will just tidy it up and put it to bed in the meantime.
RodneyFord , 09-20-2018 07:00 PM
A while ago I got some canopies from Tower Hobbies for another project. Any of them would fit the Calypso. The cowl is a bit more problematic. The options are, a mold, lost foam fiberglass, wood/fiberglass.
RodneyFord , 09-25-2018 01:51 PM
Continued working on the drawing. I have done a drawing for a wood cowl which could be used for making a pattern for molding or glassed and used as is.
