Things to do
Hi Rodney
I was able to view the pdf... There are a few small issues with the plan that you may like to update
Paper Size Please make sure the Width of the plan is only 36 inches:- as this is the max paper size on a plotter the paper is on a roll therefore length can be what ever you like, . This will make Printing the plan easy,,,,We all want get a print made.so we can build one
Line Thickness on the drawing, you need to mage the lines a little thicker and all of them black, I know color looks nice but outputting is is a issue for some Plotters (Mine is a old HP 755cm)
Put a border around your plan with a scale on it so you can check the plot is correct.
Wood and sizes:- you need add these
Allow for the sheeting thickness on the foam wing and stab
I hope my feedback is help full and you have done a great job
last Put your name on it you have done a good job (My Tech Drawing Teacher would always insist on it)
Regards
John Papandreou
