Hammer 40 length mod
I just bought a Hammer 40 short kit and from the looks of it a lot of people here have had Hammers so I'm hoping I can get some advice.. One thing that surprised me since it is advertised as a pattern plane is the length is only 80% of the wingspan. I'm thinking of adding 6 to 8 inches in the fuse between the wing and the vertical stab and possibly 2 inches to the nose. Has anyone here done anything like that? Also, the plans call for some dihedral in the wings. Has anyone reduced this or taken it out?
Do you want to fly a Hammer .40? If you add length to it then you're not flying a Hammer .40.
A lot of the old designs are short by today's standard, I'm not sure why? Some of the engines back then where a bit on the vibratory side so maybe they had to shorten the heavy fuse a bit to keep the weight down? Maybe they were influenced by full sized planes? Who knows, but they didn't seem to start lengthening planes until the mid 80's.
The plane won't fly "wrong" with extra length and if you build it light you may not have to add much extra to the nose as the CG will most like have to move further back too unless you make the stab area smaller.
With the low-wing configuration, the designed amount of dihedral has probably been incorporated to avoid roll-coupling when rudder is applied. (A low-wing pattern plane typically requires about 2 degrees of dihedral at each wing-half.) Accordingly, one can maintain knife-edge flight with the application of only the rudder. If you reduce the dihedral you will probably induce adverse roll when rudder is applied (i.e. right rudder => left roll; left rudder => right roll).
The Hammer 40 is a “classic” style pattern/aerobatic airplane. It was built in many different sizes. (Tack Hammer— Sledge Hammer: 1/2A — gas engine). If you lengthen it as much as you plan, it will no longer perform like a “classic” pattern plane.
The Hammer 40 was my second plane and my second build way back in about 88. I was serious about aerobatics more so than sport and was advised to take this plane over the Hotts. We had 3 or 4 of them in Jamaica at the time.
The Hammer flew extremely neutral and light, and I learned knife edge both ways with it. No bad habbits at all. Only downsides were the rudder Iis thinksmall ,the wing was too thick, didnt stall easily. We shaved the leading edge on one and it did better at spins etc.
With dihedral about 1/4" per wingtip there was no roll in knife edge. Mine had almost no pitch down couple...for this I would rate the Hammer higher than the ultrasports, kaos, etc.
My mods were stiffening the back end where the stab is mounted with 1/64"ply, a larger sub fin and a rudder double the size. The 46sf was a bit underpowered by today's standard for the size airframe, even with the pipe. Flew one with a 60, but prop clearance was an issue. That was eventually converted to tailwheel.
In your case I think discreetly adding 2 inches length to the hinge line, then doubling the rudder in a way to preserve the looks and shape would be very cool and give the effect you want.
I may suggest also lowering the stab about 1".
Actually i meant to lengthen by 2" from back of the wing to rudder hinge line. Then a larger rudder would give you maybe 3" more. Total 5" added. Fin and sub fin can be massaged to preserve the looks.
VERY INTERESTED IN HOW IT WORKS OUT.
From my experience: if the current stab position produces no pitch-down-couple with the application of rudder, then lowering the stab may induce a pitch-up couple (toward the canopy) when rudder is applied
Very good information. 5 extra inches with most of it in the rudder is a good suggestion. The plans call out solid tail surfaces but if I build them up I can reduce the amount of weight gain. I'm thinking of a 46 to 60 size electric motor. I'll write what I do and post photos when I get time to do it.
The Hammer would pitch down some when the rudder is hard over (but not as bad as some other hi stab designs). I can't say for sure if lowering by one inch may be too much correction.
Mine was built with a hatch under the nose to access the tank. I eventually sold my hammer. It was lost because the owner placed the battery under the tank, and the hatch somehow fell off and battery fell out.
I'm thinking that you would have your lipos inside the nose with similar access hatch.
Yes the battery will go where the tank would normally go. This is another place that may grow slightly to accomodate a longer battery. I have to wait and see.
Very interesting. I am almost feeling like building a Hammer, the looks and colour scheme on the box takes me way back to my teens. No extra storage space for now...
For now I am getting ready to build a Great Planes Super Aeromaster 60 from eBay, with many modifications.
