Smoke PUMPS
#51
Smoke PUMPS
That's the one!
If you want to do without a servo, you'll need an electronic switch. You can buy them or make one from radio shack parts, but either way, it's gonna cost more in time and money than a cheap servo. I just use a servo with a micro-switch (also available at Radio Shack). Just mount the switch so that the servo hits it. (Make sure it's a push-on, release-off switch)
#52
Smoke PUMPS
How would I go about wiring the switch up? Would I plug the pump into an aux channel, and then plug the servo into the gear channel and put the switch in between the pump and the receiver?
Thanks guys!!!
P.S. There is a funfly this weekend and I would sure like to surprise a few people by breaking out the smoke!!!
Seth
Thanks guys!!!
Seth
#55
Smoke PUMPS
Do you use a rod between the servo arm and the switch, or just touch the arm directly to the switch?
Also, do you have a pic of your entire system, or a diagram so that I can get a handle on the entire system.
Sorry for all the questions, I haven't had any previous smoke experience, and I haven't even though about it until this week.
Thanks Again
Seth
Thanks Again
Seth
#59
ON, CANADA
Smoke PUMPS
Hi guys - have been reading about the smoke systems as I want to put one in my Edge 540. The Wal Mart pump seems the way to go from what i have read - how about the smoke - you guys that are having success getting lots of smoke, what do you use?
tfacr
tfacr
#61
My Feedback: (31)
NC
Smoke PUMPS
i have been using that old hard yellow gas line. i put a piece of regular silicon on the last few inches for the muffler as the yellow stuff could not take the heat. i perfer the blue aeropro gas lines as it stays softer. i use in on all my gasser. I am not sure if it will take the muffler head that is why i used the system above.
#62
Smoke PUMPS
Originally posted by hdsprockett
Mike:
What do you use as a check valve? Will the ones that are for automotive vacuum lines work?
Mike:
tfacr
tfacr
Also, what type of fuel line are you using for the smoke fluid - the regular silicon stuff or what?
tfacr
tfacr
#66
My Feedback: (31)
NC
Smoke PUMPS
i tried smoke oil also i cannot tell the difference!!! try it u will c what i mean.....
i use gas tubing seeing how the mixture is not of the glow fuel type... and more on the gas type....
#67
Smoke PUMPS
Originally posted by JohnVH
What is the least messy smoke oil??
PS Keep in mind that all the smoke in the pic below is coming from only a YS 91AC.
#68
My Feedback: (84)
IA
Smoke PUMPS
How has this worked out for those of you that tried it? I am wondering about the seals in the unit failing because of petroleum product through it. Also is there a radio interference problem? If they are brushless then I would think it wouldn't bother.
#69
ON, CANADA
Smoke PUMPS
Hi Guys - I am about to install a windshield washer pump using a home made smoke setup as talked about in this forum. Has anyone experienced radio interference with the washer pump? If so, how did you counteract it?
tfacr
tfacr
#72
Smoke PUMPS
One caution about the diesel or kerosene, they will eat foam. My 10+ year old planes now have some parts of the foam sheeted wings missing the foam inside! I had to poke holes and shoot some expanding foam insulation in to replace it. No matter how well you try to seal the covering the oil will get in sooner or later. The smell ain't the greatest either, but hey the price is right compared to the high priced stuff.
You can buy the Bennett pump for about $25 without the valves, tubing etc. Or you can go to a snowmobile dealer and buy the exact same pump for the same price. Some lawn mowers probably use similar crankcase pumps. Mine is off one of my ultralight engines. One nice feature of these types of pumps is that the flow is automatically regulated by the engine speed.
I don't know about the smaller engines but they work great on gassers. I fly Bennett's smoke and kerosene 50/50 to cut down on the cost. Just some thoughts
#73
Smoke PUMPS
I use 99% pure liquid paraffin that I get from the local restaurant supply store (it is used in the floating restaurant candles). Cost is a miserly $7.00 a gallon! It is totally clear and it burns real clean and dry! I burned through 4 - 16 oz. tanks last Sunday and I barely had any residue on my plane! Smoke is pretty darn good and I get compliments on it all the time! Regards,
astrohog
astrohog
#74
ON, CANADA
Smoke PUMPS
Thanks for the smoke fuel tip astrohog; sounds (and smells better)than kero!
I asked about RC noise from a windshield washer pump and still don't have a good answer yet. Radio Shack doesn't have isolators as suggested by one modeller.
Would aluminum foil work OK around the washer pump to supress RF noise or it this necessary?
tfacr
tfacr
#75
Smoke PUMPS
Yeah astrohog, good tip! My buddy chopped up a bunch of candles and put it in his kero, but it didn't work too well.
tfacr, I'll tell you the name of the elctronic thingies when I get home tonight. I have a few that came with my speed control for one of my electric planes. They connect between the two motor poles.
