The Clubhouse If it doesn't fit in any other category and is about general RC stuff then post it here at the Clubhouse.
Smoke PUMPS
Old 01-14-2003, 02:56 PM
wuudogg
My Feedback: (14)
Default got the last one...
got the last one.... found it right on top of the wiper blade section.
Old 01-28-2003, 03:13 AM
raven7usa
My Feedback: (7)
Default makin' smoke
Have any of you tried 'bleach' as a smoke fluid? It used to really put out some heavy white smoke off the rear tires. Much better than a water burnout. (Something the driver's ed. teacher never got around to teaching.)
Old 01-30-2003, 03:15 AM
DFWS
My Feedback: (8)
Default Smoke Systems?
This is what it should look like when you get it working right!!!!
Old 01-30-2003, 03:17 AM
smartwork
Default Smoke PUMPS
Awesome. Which pump system, smoke oil, and engine?
-s
Old 01-30-2003, 02:53 PM
MinnFlyer
MinnFlyer's Avatar
Default Or this...
This is a TME pump with Ultrasmoke oil
Old 01-30-2003, 08:18 PM
  #31
Bill Vargas
Default Re: Smoke PUMPS
Originally posted by RC_Boy_12
I dont know if i am in the right place or not but maybe you guys can help.
I want to buy a smoke pump for my p-40 but i dont know what kind,what make,what i need...Ect....I know about the TME pumps but i dont know if there is maybe a cheaper one or what so plz help...
Try Giving Slimline a call about there New Smoke Pumps! I spoke with Ron and Bill about'm and they are very cool looking too
BV
Old 02-19-2003, 04:58 PM
  #32
krayzc-RCU
My Feedback: (31)
Default Smoke PUMPS
i have heard of some flyers mixing their own oil what all is the mixture and receipts for this?
Old 02-28-2003, 03:54 AM
  #33
paulfromero
Default Smoke PUMPS
Hi,
Saw one Post regarding the Perry Crankcase pump not working too good. I would like to know from others if they have tried this pump for use in a smoke system, and what kind of results were had? Thanks in advance for any infos.
Paul
Old 02-28-2003, 04:12 AM
  #34
smartwork
Default Smoke PUMPS
Hey there, Paul -
That post may have been mine. I have a Perry crankcase pump on a 2.4 Brison Gasser and don't like it a bit. I'll be changing to either a B&B or one of the battery operated (didn't want the weight) systems. As for battery types, I see a lot of TME posts and even one thread about the fellow getting the windshield fluid pump from Wal-Mart - which I think he mentioned was the same pump as sold by some RC brands. I would have to review the post to confirm details.
From my experience, it just seems like the Perry can't keep up and I've tried all different fluid amounts. One good thing about the Perry is that it does have a needle valve for control so I'll probably keep that installed for the new pump I use.
-s
Old 02-28-2003, 04:27 AM
  #35
paulfromero
Default Bigger pump for big engine?
Hi,
I did a search on smoke pump systems and found out someone was selling their B&B pump system for about $40. Seeing the prices on the TME etc. This may be a great deal for ya. I have a ST .61 2 cycle that I plan on installing the Perry crankcase pump on ( I already had bought it). Do you think that with the smaller engine, the Perry pump might work out? My second choice would be to go with the MACS products pressure system at $30. Any observations...
Paul
Old 02-28-2003, 04:33 AM
  #36
smartwork
Default Smoke PUMPS
Oh, now for a .61, it may indeed do the trick. That'll be quite a difference than it trying to keep up with the gasser. Your issue may be needing a heater coil in the muffler to hit the temps for thick smoke.
40 bucks for a B&B, eh? Hmmm... may have to check that out.
Thanks!
-s
Old 03-04-2003, 10:28 PM
  #37
paulfromero
Default Smoke PUMPS
Hi,
I need to complete my TME system. Is it necessary to get a smoke muffler (over $70 bucks!) to use with a YS.91FZ? The goal of course is to have good 1st class smoke.
Thanks for infos guys,
Paul
Old 03-10-2003, 08:47 PM
  #38
Robert300XS
Robert300XS's Avatar
Default Pre-Heater
Here's a cheap preheater. Basically take some tubing and coil it around the muffler several times, preferrably in the hottest area, then have the smoke oil go though the coil then out into a nipple, also preferrable in the hottest area. I did this on my Saito 150, but the coil was on the header pipe. It smoked awesome, just could have used a better smoke oil, I was experimenting with tranny fluid and tiki oil.
Old 03-10-2003, 09:19 PM
  #39
MinnFlyer
MinnFlyer's Avatar
Default Smoke PUMPS
Paul, look at my post earlier in this thread. This is using a YS 91AC (basically the same engine you have) with no preheater. The only thing I did was to wrap the muffler with a little fiberglass insulation to keep the heat in. (And I don't even know if THAT'S necessary)
Old 03-11-2003, 02:51 AM
  #40
paulfromero
Default Smoke PUMPS
Hi,
Lots of great infos guys. Thanks for the nice graphic too! I dove in and bought a used slimline smoke muffler from one of our fellow members here at RCU. Spent a dime for convenience, but next time....
Ciao,
Paul
Old 03-11-2003, 01:36 PM
  #41
Unstable
Default Smoke PUMPS
I STILL cant find a pump at the local wally world... I went a few weeks ago then again and they dont have them..
I guess the super chippy is going to have to live without smoke for a bit longer (I need a new muffler on it anyway... the one I was going to use doesnt give enough back pressure.)
Old 03-11-2003, 02:18 PM
  #42
MinnFlyer
MinnFlyer's Avatar
Default Smoke PUMPS
Chris, Ask one of the Aisle Apes of they can order one for you. You could also check KaMe apart Or Target, or even a local Auto Parts store
Old 03-11-2003, 02:58 PM
  #43
Robert300XS
Default Smoke PUMPS
Go to AutoZone and get the $10 Universal pump that they have. I have that one right now and am making a servo/switch tray. I will get some pics soon.
Old 03-11-2003, 04:08 PM
  #44
raven7usa
My Feedback: (7)
Default Washer pump
Unstable, I found the windshield washer pump on the top shelf above the wiper blades at Wal-Mart.
Old 03-11-2003, 04:16 PM
  #45
Robert300XS
Default Smoke PUMPS
I went to walmart today, they said they don't carry washer pumps anymore.
Old 03-13-2003, 07:53 AM
  #46
Grampaw
Default Smoke PUMPS
A few days ago while going through some mags from '93 I ran across an ad for a smoke maker. Don't recall the name of the company, but this set up had the smoke fluid running through a "Preheater" before going to the muffler.
Anyone have any idea of what that "preheater' consisted of?
I have an idea kicking around in my head to make one, but I'd like to hear from any of you who have had some experience with smokers before I start experimenting. A "Preheater sounds like a better idea than wrapping tubing around the cylinder head.
Old 03-13-2003, 03:21 PM
  #47
MinnFlyer
MinnFlyer's Avatar
Default Smoke PUMPS
A perheater is exactly that... Wrapping a tubing around the cylinder head, or muffler. Sometimes even having coils of tubing inside the muffler.
Old 03-18-2003, 06:32 AM
  #48
sandrews
Default Smoke PUMPS
Found a pump at Walmart today!!
Old 03-18-2003, 06:34 AM
  #49
sandrews
Default Smoke PUMPS
What's the next step in the home-made smoke process? I have a saito 120 with a Slimline smoke muffler. The plane is a Goldberg Ultimate Bipe.
Old 03-18-2003, 07:26 AM
  #50
sandrews
Default Smoke PUMPS
Also, how do I wire up the pump without the use of a servo. I tried plugging the pump into my gear channel, but the pump ran continually. The tme pump says it plugs into an extra channel without the use of an extra servo or battery. How does this work?
Seth
