trainer multi
RE: trainer multi
Very cool, looking forward to the video!
Just reread your post, its a dang shame it crashed! I forgot which forum I was in..Sorry again on the demise of such a cool plane!
RE: trainer multi
one bank of engines was stronger than the other. this caused some uncontrolable snaping. the crash did very little damage. the wing got gouged by the rubber bands and that was it. the plane was built and flown by another pilot at my field. the plane was restranied by two people before take off. it had a very close call with another pilot at a flight station. as soon as i can figure out how to compess the video ill email it to our clubs web master .
ORIGINAL: stikman26
that looks cool, how far did ya get before it crashed? damn shame
RE: trainer multi
It's fixed and we spent a while trying to synch the motors, the problem is the outboard motors cause a lot of yaw if they are not syched. Will try another flight in the spring. The first flight was long enough that we know she's very overpowered and quite fast, especially for a trainer...
RE: trainer multi
I suggest you post this on the Twin & Multi Engine RC Aircraft forum. You did not mention engine size, weight of plane, wing span. The wing being held on with rubber bands is surprising. I would put on many, many, many more rubber bands. If the plane can takeoff on two engines, you might consider removing the outboard engines until the plane is tested.
RE: trainer multi
ORIGINAL: Villa
My Feedback: (18)
RE: trainer multi
Plane specs are NOT required to post in this forum..
Altho some of us would like them as it is always nice to see what others are trying...
The only "suggested recommendations" are that we all play nice and have F U N ....
RE: trainer multi
I agree. Villa, thanks for modifying your post it is much less agressive. Goliath did the original post and I doubt he had specs. It is a Tower Hobbies trainer. Span 62". The front motor was removed and a cowl from a twinstar repainted and installed. Four old OS FP.25's were put in with 6oz tanks and a servo for each. I already hade the aluminum landing gear on it, every trainer should have this. Final weigh is much higher than the original trainer, almost 7 pounds. It takes off and flys like a trainer except for the yaw from the unsyched engines it flew well. I didn't get to land it but the one flight did end in an engine off landing off the runway that damaged an old repair at the leading edge where the rubber bands go across.
The OS.25's where last used on the flying saucer in the post with all the pictures. That didn't work too well either but I just had to try it. Throttle lag from the motors caused it to lift unevenly. I should have kept it(I threw it away) and tried it with modern electric motors, it would fly well on electrics....
The pictures are just some of my creations, I like different things....
RE: trainer multi
evan-RCU
I suggested posting on Twin & Multi Engine RC Aircraft forum because that is were the best advice is for multiple engines. If I knew a little more of the plane specs I could have made a better suggestion. Please read my input with a positive, neutral outlook. I did not post the second message you refer to. From what I saw and read I thought there was a great deal of danger involved but there was not enough information for me to mention it.
RE: trainer multi
Robby, question, not to be rude but why did you modify both of the posts that Villa made? Though I don't agree with him, or didn't with what he originally said, I didn't have a problem with what he said, friendly bantering so to speak. I did send him a PM to discuss my opinions privately.
Curious....
Curious....
GA
RE: trainer multi
evan-rcu,
Is that Giant Quaker pictured at Triple Tree Aerodrome? Wow, it looks different in the fall. I'm always used to it at Joe Nall.
Stinger
Stinger
RE: trainer multi
ORIGINAL: stinger40
evan-rcu,
Stinger
evan-rcu,
Stinger
RE: trainer multi
No, I belive Pat's is 25 foot. Did you know when he moved it from his house to the new hanger at Triple Tree he flew it there? He had a lead airplane he was in and he controlled it from there while in the air.
GA
RE: trainer multi
Whoa, I didn't know that. That's cool. It won't fit in any car. Do you know what plane he was in? I would assume the Stearman, because he can see all ways in it. Either that, or the J3 Cub. It would have been bad to have a dead stick. Which one did he land first, I ask myself.
RE: trainer multi
I think it was the stearman but I'm not sure, The Quaker cruises above 100mph so matching speed wasn't a concern. It's looks much slower than it is because of the size.
I think we have hijacked this thread......
GA
RE: trainer multi
ORIGINAL: evan-RCU
CO
RE: trainer multi
They should change the outboards to pusher props and put them behind the inboard engine. A push me pull me airplane not on centerline. That'd be sweet.
