Blade CX-2
#2676
IN
RE: Blade CX-2
Spuratic,
Go for the Extreme 850 mAh 20C... The 20C will give you alot more horse power than a 10C. And the difference in the mAh rating will be negligable... Depends on what ya wanna do.....and your flying style.
Dave / Choppersrule
Dave / Choppersrule
ORIGINAL: spuratic
Whats every body's experience with battery's? i'm looking at getting either a Extreme 850mah 20c or the DN 900mah 10c? Im not sure what to get and any input would be greatly appreciated.
#2677
CA
RE: Blade CX-2
Personally I like the DN, CSRC and MegaPower ones. They're pretty cheap too, and I don't think your going to need a 850Mah 20C pack for the CX's.
#2679
MI
RE: Blade CX-2
Was wondering what the weight difference is between the extreme landing skids, canopy, and tail boom are in comparison to the stock stuff? i would assume that it may be a little lighter.
#2680
MD
RE: Blade CX-2
hi guys, i was just wondering if anybody put one of these on their cx2? and if so where did you put it? thanks http://www.horizonhobby.com/Products...odID=EFLRG90HL
#2681
MI
RE: Blade CX-2
If i were to put a HH gyro on my heli i would go to boomtownhobbies and buy the boom kit. Then you can put it on the back easily. And i will also sell you my telebe headlock gyro for $40.00 plus shipping. I have only used it through about 5 battery cycles in my cp pro, but am now parting the chopper out and flying the cx2 and saving for a T-rex.
#2682
MD
RE: Blade CX-2
thanks for the offer, but i already have the other one i linked to. i was just wondering where it would go. i so guess there is a space on an after market tail boom? do you have a link to one? thanks again
#2683
AZ
RE: Blade CX-2
Hey guys,
Im currently in the process of removing the gears to switch to the 180 motor. But im having a major problem removing the screw from the retaining collar. I went out and bought a better screw driver and even then I cant get this damn screw off! Is there any tricks to this? Or do I just have keep trying? I just dont want to bend the shaft connected to it!
#2684
RE: Blade CX-2
I had the same problem, I just got a small presision needle nose and squeezed down on it and turned it a little until it broke free then I used my screwdriver to remove it... I changed out that screw on the re-install..... Good luck with the 180's (i'm assuming your putting in the extreme 180's) let me know how it goes, I was thinking of doing the same upgrade...
Dream
Dream
#2685
MI
RE: Blade CX-2
http://www.boomtownhobbies.com/Xtrem...ks_p/xc001.htm Thats the kit that i have...you can buy the tail boom set up separate if you prefer though. Let me know what you think of the 180's your putting in.
#2686
AZ
RE: Blade CX-2
ORIGINAL: dream_mas
Dream
Dream
I'll let you know as soon as I get the son of a ***** off! I dont have a needle nose small enough so thats out. Guess ill just wait till I go back to the LHS and have them do it. I did however move the servo arm up one hole. Now I have a lot of tuning to do to hover it again. That and I need to do the flybar mod. Anyone have the link to that?
#2687
OH
RE: Blade CX-2
ORIGINAL: Dopesick
If your breaking blades while flying aggresivly, you NEED to lighten your flybar. The lower blades respond much quicker then the flybar weights will allow the upper blades to respond. Your getting the Blade Clack of Death. As discussed: http://www.rcuniverse.com/forum/m_7699962/tm.htm
I would say to you... NEVER use WD-40 as a lubricant. Its one of the worlds worst items to use as a lubricant. It's title, and use is a "Water Dispersing" agent. Hence WD, Combination #40.
If you really wish to lubricate it, I would say use a drop of silicon oil. However, IIRC that is a sealed bearing, and it won't doo too much good anyways.
ORIGINAL: aviator24
I have moved out the servo link rods for more control in the wind outside. How far can these be moved out? I am out two holes on each side and have two more holes to go?
When I get aggressive or try to avoid a crash, I seem to break blades all the time! I want to go to upgrade my blades AS CHEAPLY as possible. Would I be better off just getting a longer bar between the blades?? I have read about lightening the flybar as well as shortening it? That sounds difficult and beyond my tech skill? Pretty much all thumbs.
ORIGINAL: Roadtorque
I was looking at my swashplate on my CX2 the other day and thought about giving it a shot of oil (WD40) on the top side of the swashplate just to cut down on any friction that might be in there. Anyone see a problem with this? I figured as long as I dont get to much oil in there to drip over the motors I would be fine. What do you all think?
Chris
#2688
RE: Blade CX-2
get a mini titan!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!![X(]!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!![X(]!!!!!!!!!!!!!!!!!!!!!!!!!!![X(]!!!!!!!!!!!!![X(]!!!!!!!!!!! lol
#2689
OH
RE: Blade CX-2
I would guess that most people who enjoy the CX-2 will eventually buy a CP heli but what's that got to do with the CX-2? The Mini Titan can't replace it for indoor fun. Is it safe to assume you just got your Mini Titan and it's such a rush it leaves you delirious?[sm=spinnyeyes.gif][sm=lol.gif].
#2690
CA
RE: Blade CX-2
ORIGINAL: chris1379
#2691
RE: Blade CX-2
Hey chris1379, where do you live in dayton? I'm in Beavercreek. Just bought a CX2 about a week ago. Had a few crashes/replacements prior to hitting the forums and learning how to make adjustments. Getting better with it though. Still want to do a few upgrades/replacements but having a difficult time removing some of the screws on some of the parts. Guess I'll worry about that when I have to replace things. It seems I spend more time tyrying to tweak this thing than actually fly it.
Take care.
Take care.
#2692
AB, CANADA
RE: Blade CX-2
ORIGINAL: Swanky Pants
Great advice, Rusty.
I've had my heli for about a month now and I'm already salivating at trying a coventional heli. I had a CP a year ago and got discourged with it because I couldn't fly it. Now that I've had some airborne experience, I want to move up soon. Granted, it's a whole different bird, but I have the feel of flying a bird in front of me.
LOL I hear ya there. I love my CX2, it's the only indoor heli I got, and i have a large collection of heli's, but I ALWAYS end up going back to my t-Rex 600 or now my 700 because the CX2 just isnt challenging enough.
I recommend a t-rex 450se V2 t you when you move up. It's a high performance heli, and it will bite you when you screw up, but it is a very stable platform to learn on. it will also provide you with years of fun and enjoyment.
#2693
OH
RE: Blade CX-2
ORIGINAL: mcinturf
Take care.
Take care.
Chris
#2694
MI
RE: Blade CX-2
Ok, I am back. After a self imposed rc heli exhile for the last month, finally got the CX2 out and dusted it off. Put on a new flybar and blades. Gave her a test flight and she flew like new! Hovered so still and was able to control it really well.
Been concentrating on my planes with some bad luck as well there. Finally got them flying good, figured the heli was next!
#2695
My Feedback: (10)
RE: Blade CX-2
Whew! I just finished reading the whole thing! Took weeks (a couple a day during lunch at work) but I made it. Thank you all for the information you've shared. It's made me a good mechanic, not a better pilot but I'm still working on that.
I have the CX2 with a heatsink & skinny tail boom. I had to take the body off as there was so much tape holding it together I couldn't trim it out any more.
I do have a question though (surprise, surprise). Does anyone have any links or suggestions on how to actully fly the heli? I've Googled but keep getting hits for real flying schools for real aircraft (next life). I need a good book or forum or ... to describe what to do & how to do it.
Found piros by accident & didn't know what it was called for weeks until I saw it on a video! I can hover pretty well & working on the different orientations but ready for more adventuresome flying. Did I mention I'm confined to the living room full of furniture, TV, piano, end tables, etc? The trips outside have been VERY costly indeed!
Any suggestions would be appreciated. And thanks again for all the good stuff on this forum.
Chuck
Chuck
#2697
MI
RE: Blade CX-2
I just wrote up my whole experience with mu cx2 and the damn forum timed out and dumped my well thought out story. PISS. Sorry guys.
Here were the 3 questions I had.
Do I need any additional parts to make boomtowns extended main shaft and head work/
Is the aluminum battery tray worth the money and extra weight?
Is anyone experiencing any esc burn-downs with the 25C Lipo? Has anyone used it?
thanks,
Mikey P
thanks,
Mikey P
#2699
RE: Blade CX-2
~ Jeff
