Blade mSR servos not level ??
I just got my new Blade mSR. When fly the helicopter, I notice that the heli is kind of tip to right side about 5 degree. When I look the heli from the back, I notice that the left servo kind of higher than the left servo. Can anyone that has mSR verifty this to make sure it is normal?
I also notice that to hover steadly in one place without any transmitter input is very hard. It keep waving left and right when I try to make correction. I just wondering whether the servos not even is the cause.
PA
RE: Blade mSR servos not level ??
Mine is the same way the main shaft tilts to the right when you look at it from the back. The tail rotor is pointing up a little also. This is normal. I think.
Joe
Joe
When it hover, from the back I notice that the rotor blade spinning and the body of the Heli is little crocked to the right. IS that the same too? If it is, I think because of the 2 servos setup that allow to move 4 directions.. []
QC, CANADA
It is tilted to that side, probably to counteract the blade rotation in one direction and also give a bit of a hand to the little tail rotor.
AZ
It is normal, if you are having problems hovering, adjust your electronic trim on the remote. If it needs more than that, you can adjust the arms for more adjustment. Trimmed out, it shouldn't take much to hover.
KS
Yea mine the main shaft is titled a little towards the right however hover is not hard at all. You need to make sure you are trimming the remote correctly. I would start out without flying and making sure your servos are responding properly. Also make sure you don't have a bent arm or something. My servos are pretty much in the same spot on the board. Also you might look at the gear below the servo to make sure it's spinning properly. Just check it over real good before flying and you will probably find your issue.
