RE: Blade mSR servos not level ??
Yea mine the main shaft is titled a little towards the right however hover is not hard at all. You need to make sure you are trimming the remote correctly. I would start out without flying and making sure your servos are responding properly. Also make sure you don't have a bent arm or something. My servos are pretty much in the same spot on the board. Also you might look at the gear below the servo to make sure it's spinning properly. Just check it over real good before flying and you will probably find your issue.
