Mini Ultra Stick
#101
RE: Mini Ultra Stick
My nylon LG bolts are Sig brand 4-40 x 1/2". Found them at the LHS. I gave them a real good test today after many flights with no problems. I glanced away from my plane for an instant to see where someone else's plane was and the wind knocked my MUS down onto the runway so hard that it knocked the hatch off. I kept flying expecting the gear to fall off but it's still on there and strong as ever. Those little bolts are tough!
Welcome 66-stang. I had one of those once. Great car!
#102
Took the plunge and made the 50 mile X-Country to visit Home Depot and Lowes'. Home depot let me down and Lowes' had nylon screws from size 6 on up. Not a #4 to be had.
Still waiting for a Zippety Do Da Flight with my MUS. Fast and Furious yet my goal is landing on a 30FT RWY. The DITCH at the approach end of the RWY shears my #4 nylon screws. No damage to the FUSE YET.
I'm too green to tap or blindnut a #6 in there. I like #4's. Did a few bounce and goes and the #4 nylon held up good.
I'm so addicted to the MUS that I'm surprised I'm handling the "Patience" thing so well.
Sky
Sky
#103
ORIGINAL: skyhawk73
#104
Whats' CROW. I've come across the term several times and figure it's a complex maneuver that I'm not up to yet. I figure it's an acronym for "Curved Runway Over Water".?
#105
Flaperons ? Hummm...
I fly with a six channel Futaba Computer transmitter. I'm gonna look into the manual to see if I can configure some flaps that way. My ailerons are hooked up to #1 and #6 on the reciever in order to bypass the use of a Y cord.
Flaps would probably help since I'm at minimum controllable airspeed on final and, coming straight at me I can hardly tell how close to a stall I am. The controlls are sloppy at that airspeed but I can't afford much of a landing roll since my driveway is sorta short . I tried landing in the yard but the grass must be too thick because I can't keep the tail down after touchdown in the grass. The "nose-over" doesn't cause damage but it looks terrible. The driveway touchdowns are pretty but I gotta practice allot since I got no brakes.
#106
SK, CANADA
Crow is when the ailerons and flaps move to a set point in opposite directions (air brakes). They move together with the control of your ailerons on the transmitter. It just reduces the speed that the plane will travel. This would help with the short driveway.
#107
ORIGINAL: skyhawk73
#109
I've used flaperons on Hitec 5 & 6 channel transmitters, and the Futaba 9C. I'm not familiar with Futaba 6 channel radios, but if it's a computer one, I would think there's a way to do it. Good advice on using the knob if it's that one and checking the manual for your radio. I believe you need at least 7 channels to do crow, that's what I have the 9C for. There may be a way to do flaps with 6 channels and a "Y" cable, but I'd go for flaperons first. They should be the easiest to implement and they work very well slowing this plane down. Crow and flaps require more work and may or may not be any better than flaperons, but I just had to try 'em.
#110
NC
av8r1
I use a Spektrum DX6 with my MUS and have programmed it for flaperons. However, I've experienced smoother landings without flaps than with them. It becomes a little unstable when I turn the flaps on and does not really slow the plane down.
I'm using only 30% throw on the flaps. Is that too little?
#111
ORIGINAL: skyhawk73
#112
I don't know why I'm so concerned with the undercarriage. Now that you mention it, all my other planes have nylon screws holding the wing on. It's a no brainer that a MUS should have nylon screws on the wing as well. Thanks for shineing the light for me. Ma Bad. I'm gonna go get some nylon 6X32's from the lhs for my wing fix.. He's been trying to sell em to me along with some #6 blind nuts to replace the 4X40 setup holding the undercarriage on. I just don't have the nerve to do it fore one of you guys has tried it with success. The lhs guy did say that my changing from a 12X6 prop to a 11X7 didn't help one bit. I'm trying to slow down not speed up. I didn't notice the melodeous sound from the 11X7 nor any speed difference since I'm mainly seeking to become competent flying off my drive-way. Once that hurtle is crossed with adequate proficiency, I'll move on to evaluating speed and doing a few maneuvers. Right now, I'm engrossed in the challenge of short field LANDINGS. I got it goin on with the flaperons without a Y cord during preflight but haven't tried slow flight with full flaperons. ( I'm still grounded cause I can't find any 4X40 nylon screws. ) The idea of using flaperons might just be another factor adding to the complexity of a dooable sort field landing. I'll probably try doing it clean before I complicate things by using flaperons.
#115
Before going to the lhs to get some 6-32 nylon screws for my wing, I checked the MUS assembly manual only to find that it calls for the perverbial 4-40 screws there too. Are you sure that a 6-32 nylon screw will fit the wing fittings?
I recently changed my shaft in my 480 brushless motor. Not a big deal with the .050 allen wrench. The shaft (EFLM1501) cost $4 from Horrizon.
I asked Horrizon what they recomended for a receiver and they said the Hitec Electron 6 with eflight S75 sub micro servos. I told them I like getting hitec S55 servos from my lhs. Horrizon said the PNP is outfitted with eflight S75 which have been found to out perform the hitec S55's and cost the same price.
I use a hemostat to remove the sheared nylon screw from within the fuse. I can't believe I've done it ten times without damage to the fuse. The manual calls for a 4-40 1/2 inch screw for the landing gear but if you use a longer nylon screw it's a piece of cake to remove when it shears.
I hope to advance to a point where I no longer shear the nylon screw holding the landing gear on. Today, I'm bummed out because shipment of 4-40 nylon screws is delayed.
I live across from a golf course. I do maneuvers over fairway #5 then approach with a long final to a 50 foot driveway. My truck is usually parked in the last 18 feet so I'm trying to land in the first 30 ft. I don't know how to put a pic of my runway on here but after doing several successful landings, I know it can be done in 30 ft. I love the way the MUS kicks to the left at the end of it's landing rollout. If I could only perfect the precision touchdown point, I'd be a happy flyer. It will happen in time. Those successful landings were with a 12X6e prop and then I went with the 11X7 because one of you guys said it sounded better and thats when all hell broke loose and I sheared several #4 screws. My LHS guy intellectually said go back to the 12X6e prop but now I can't find a #4 screw.
#116
ORIGINAL: jmir
av8r1
av8r1
#117
NC
I'll try less flaperon to see if it helps. I was using a 10 X 3.8 prop for a little more power, trying to hover, but I was not very successful. I'm currently using a 10 X 7 prop which works very good for me. I take off and land at a regular airfield with a 2,800 foot runway and lots of open space. But, they don't mow the grass very low, so the shorter prop works better on grass landings and take offs.
I don't have any problems with smooth landings without flaperons. The MUS is very stable. Just wanted to experiment with it and see if I could slow it down even further.
I've been looking at the ultra stick 25E and hearing good things about it. Maybe, just maybe, that may be my next airplane since I like the MUS so much.
Thanks for the comments/advice.
#118
SK, CANADA
This is my conversion for a tail wheel on the MUS. Works great and the magnet is more than strong enough to hold the wheel in place. With the magnet there is no stress put on the rudder servo. I've put in 4 flights since the conversion and it works great!
#119
AL
Hello, I am about to loose my land flying field and need a sport plane on floats. I like the MUS pnp. I want to keep it cheap so I wanted the mini. Has anyone put floats on it. Thank you
#121
ORIGINAL: jmir
Once nylon screws brake off, do you have a problem digging them out?
ORIGINAL: mrdakota
Twisting a #11 x-acto blade does the job for me.
Jamming an Xacto blade into the bolt and twisting it like a screwdriver will work and we did it that way for years, but that's the hard way. I've found it easier to use longer nylon bolts, pull the wing off, and twist them out from the top side with a pair of hemostats or plyers.
EDIT
ORIGINAL: skyhawk73
More Editing
Since I fly off a hard runway, this is a little tough on the tail skids. Thbe little studs that extend from the skid into the stabilizer aren't very long, and it doesn't take much to pull them out. One thing I discovered it the studs are spaced exactly like the ones on the skids that come with the mini Edge 540 and mini Funtana. If you drill the eixisting holes a little larger and deeper the Mini Edge/Funtana skid fits just fine, but then if you glue it in, you give up the ability to remove/adjust the stabilizer.
I got around this by using a Dubro allen servo screw. The screw is long enough that it goes through the stab and into the plyweood on the bottom of the fuse, so you don't have to worry about it pulling out. If I break a skid, I just remove the screw and it comes right off.
Also, with the 480 motor and big 2100mah battery, the Minis usually come out a bit nose heavy, and the Dubro screw is long enough that I can run it through an 1/8 ouch of lead before I install it. This makes for a nice, adjustable tail weight mount. I hate to add an weight, but I've got everything as far back as I can get it.
I suppose with a little more effort I could just as easily instal a decent tail wheel and that would give me a litte needed weight back there, but I'm waiting for E Flite to update the plane. They are putting tailwheels on the 25E and the new Mini Pulse has one too. The way those wheels are installed they don't look like they will cause any problems. The one on my 25Eworks beautifully and I didn't have to do a thing to it. It came pre-installed on the fin assembly and all I did was put the fin on the exact same way I do with the mini. It's very well though out and executed.
E flite hasn't updated the Mini Ultra Stick because enough of us haven't been complaining over it, so make your feelings known that you'de like a factory installed tailwheel for your mini. I would rather just buy a replacement tail section for $15 or $20 with the tailwheel installed than chop up my existing plane. I'de pay $20 for a mini kit if it came with the tailwheel installed, especially if it's done as nicely as it is on the 25E
#122
I have really enjoyed flying the Slow Stick with uneventfull landings in my front yard and back yard. However, enough already with only the rudder and elevator. I'm not kewl enough to install ailerons on my Slow Stick. Therefore, I asked my LHS to find me a plane symetrical wings and ailerons that might be flown in tight spaces.
I was thrilled when he produced such a fine plane as the MUS. He cautioned me to fly the MUS at the flying field for awhile before attempting to fly it at home. Flight in "wide open spaces" was sooo enjoyable with the MUS. Even Short Field approaches and landings were predictable. However, the transition to flying at home has not been pretty nor enjoyable. I'm on my third MUS still trying to stay out of the trees, ditches and power lines.
It took me three hours to get my newest MUS out of a nearby tree and the frustration has me thinking that the MUS is much too fast for tight flying. I'm to the point where I think nothing can replace the Slow Stick but I hate to go back to it after getting to know the MUS. After a taste of the MUS, the Slow Stick will be boring. If I'm goin to the airfield, I'd rather fly my Nitro stuff and keep the park flyer stuff for at home. Sadly, the MUS falls "in between".
#123
NC
Take a look at E-flite's Ultimate FX. I fly mine in very tight spaces as well as open fields. No problem flying it in my front yard, especially doing harriers and hovers. I must admit, I like flying it in open fields much better, without having to worry about trees, power lines and the house!!
#124
AL
ORIGINAL: planetwister
I going to put floats on mine, my LHS is ordering me an MUS today. I am going to use GWS floats.
