Replicating engine starting sequence of actual aircraft on model airplane
ON, CANADA
1 Post
Well i'm wondering if there is a system module that is programmable for multi engine models to set up starting delay and sequence engine start up as there actual counterparts in real life. Lets say if a start up sequence of actual aircraft is eng #3 first, then eng# 4, then eng#2 and last is eng# 1 to be started, how can this sequence be adapted on models airplanes. Basically once batteries are plugged in, system is armed, to activate it, turn throttle stick full up n bring it down or by flicking a toggle switch on your TX....
Anyone knows of any system available or could be adapted to do engine start up sequencing.....
