Electric motor with switch harness
MA
The motor plugs into the ESC, the ESC plugs into the battery, the receiver plug of the ESC plugs into the switch harness (shown in my post above), then the switch harness plugs into the receiver.
With the ESC plugged into the switch harness, and the switch harness into the receiver, wouldn't the ESC and everything else be turned off when the switch is off position? As it is with a nitro plane.
MO
being a newbee to electrics I am wondering the same thing, but wouldn't adding a regular switch, that comes with a radio, between the SBEC and the receiver accomplish the same thing. I understand that the battery (a 6 cell 4000 mah) will still drain if left plugged in for extended period of time.
Again,, the switch you referenced in post #25 will function the same as I described in post #24. The power to the receiver is switched on&off between the ESC and the receiver. The battery is plugged in directly to the ESC in this configuration and the ESC is always draining power even though the "switch" to the receiver is off. You can treat the plane like you would a typical glow plane and it will be safe as long as the switch is off BUT don't leave the battery in and connected for a long period of time(a day or more) as the ESC will drain it down.
The ESC is an active device which means it will always draw power when a battery is connected to it. It will not arm and power the motor until it sees a signal from the receiver. When you turn the switch on that makes the connection between the ESC and receiver and then the ESC can arm and power the motor. An analogy would be the radio in your automobile. When the car is parked/key out, the radio still draws power from the battery (to keep the clock,station presets,active) and the radio only becomes active when you turn on the key.
OK . I just programmed a plane on my heli radio and programmed a mix for thro-thro @ -100/-100 and set it to a two position switch with the offset maxed out @-125 and it works .
With the switch ON the plane is active all but the throttle. Turn the switch off and the throttle is now active. Very similar to heli throttle hold.
SHD3920, depending on what radio you are using you may be able to do this
I just tried my other radios using the Throttle Cut feature typically used for glow/gas set-ups. It won't work with an electric set-up.
However programming a mix in a similar fashion as above and with a little tweaking does work.
Perhaps on some radios the Throttle Cut may work with electrics but not on mine.
#31
Moderator
then solder a simple on/off switch to the wires on the ESC that connect the battery to the ESC. (the switch will then do exactly the same thing as unplugging the battery does.)
note: only use a switch arrangement like this on smallish park flyers. for bigger airplanes use a proper arming system. (IF the switch does fail in flight, you'll have no motor power AND no radio power.)
http://www.rcuniverse.com/magazine/a...article_id=172
hope that helps!
#32
MA
OK So save my money and unnecessary weight to the plane and do not add anything and continue to unplug the battery when not in use. Even with a switch I will still need to unplug the battery. All makes sense. Thank you for your help.
#33
CA
I would like to add another thought to this...
Why do you want to leave the battery plugged in to the plane? Are you leaving it in the plane while charging? That is not a good idea with a Lipo battery. I have seen one ignite while charging and the only reason it didnt burn the kitchen was that it was in a ceramic container.
#34
IL
On my giant scale EP planes I stopped using plugs, because I was afraid of the high amps going thru them. My hatches are large enough to get at the lipos fast.
#35
My Feedback: (13)
I just programmed Throttle Cut into my new Sig Sbach XA41. Futaba 12Z, throttle cut at 0% (bottom stick), works like a champ, the throttle stick is inoperative when the mix is activated. I used a three-position switch, so I must go through two positive detents to turn this on/off.
One thing… this model has a separate receiver battery due to the servos I used not being rated for six volts. The ESC BEC circuit is dead (I cut the red wire, to prevent two sources of power to the receiver); which means that even though the motor has power and is armed when the big battery is plugged in, I must turn the receiver on before it will send commands to the motor.
That would work as a "safety"; but I prefer doing it from the transmitter. This way I can have everything "turned on" before I pick the model up, but the throttle stick is disabled and the only way the motor will run is if something fails in the system. Once I have the model safely on the ground in the pits, then I can go through my last pre-flight checks (servo direction, etc.) without having to bend over again. When I'm satisfied, I flip off the Throttle Cut mix and buzz away.
It works on this particular set-up. The rest of my e-ships have the BEC operative and work off of the big battery. My point here is, I have yet to determine if Throttle Cut works on that sort of set-up. I'll find out later; right now we've got severe clear, light winds, and a new model to maiden. As soon as the TP 4S 3900s charge up, I'm outta here!
Lopflyer, thanks a ton for this tip. Its one of those "Now, why didn't _I_ think of that???" deals. I just hope it works on my other planes; but the 12Z is full-featured, so if I have to do a program mix of some sort on them I can still put it on the same switch so I don't confuse myself.
I have had a lot of folks ask me why I needed "so much radio"… things like this is why.
#36
MA
I really need a graph to show how this is done. After soldering the switch to the battery wire, where then does the battery plug into?
#37
CA
You can solder the switch to either wire, all you have to do is break the circuit..... but
If the idea is to leave the battery in the plane all the time, including when charging, thats not a good idea. don't you have more than one battery for the plane?
Forgive me if I'm wrong, but it sounds to me like the OP does not EVER want to have to unplug the battery, even for charging.
#38
MA
#39
Moderator
AMA 74894, there are 2 wires for the battery. Which wire do you solder the switch to? I will be using a 2-wired switch harness (one without a charging wire) that I already have so I won't have to buy one. What wire of that would I solder to the ESC battery wire? And what to do with the 2nd wire? Sorry to sound so ignorant, but I am.
you want the switch to be soldered to the ESC's input wires, not the battery's wires (if you put the switch on the battery, you'd need a switch on every battery)
look at how the electricity would flow out of the battery and into the ESC. the battery needs to have BOTH wires connected to complete the circuit, so as BadSplice pointed out, the switch only needs to be soldered to one of the two wires.
you would cut the RED wire on the ESC between the battery plug and the ESC itself.
the switch should have two solder connections, solder one of the wires you just cut to one connection on the switch, solder the other wire you just cut to the other connection on the switch.
done.
#41
Moderator
I don't disagree Les, the switch I pictured would ONLY be used in a 1/2A sized airplane, but your point is well taken.
to shd3920, I'm going to go back to your post #3 with the picture of the arming plug, because I think this is where you're getting confused...
this arming device is placed between the battery and the ESC, and not between the ESC and the receiver.
(in other words, you would plug the battery into the pictured arming circuit, then you'd plug the ESC into the other plug on that same arming circuit, )
by putting the device between the battery and the esc, when the arming plug (which itself is essentially a manual switch) is removed, that opens the circuit, completey disconnecting the battery from everything.
(removing the arming plug does the same thing as unplugging the battery.)
#42
We already addressed the arming switches with the OP. After discovering it is a 1/2a plane there probably won't be much space inside for all of that..
If the OP is going to use a simple switch make sure the switch can handle 10-15 amps . Unknown what set-up he is running but 10-15 amps sounds about right.
To the OP ; If the plane is that difficult to take apart and get to the battery and you are not comfortable making, soldering in switches , here is an option. Drill two small holes in the fuselage near where the battery connector plugs into the ESC large enough to fit a JST plug/connector. Slide the JST plug out on hole and the connector out the other so they are outside the fuse. Plug the JST's together to power the plane and then unplug them when done.,.....never have to take the plane apart and remove the battery.
#43
Moderator
flyinwalenda, exactly.
shd 3920 is / was getting confused as to WHERE the switch / arming device should go. when shown that arming switch in post #3 he was asking about how it would attach between the ESC and the receiver.
I was simply making sure he understands the device should be between the battery and the ESC, not between the ESC and receiver, and that only one wire needs to have the device on it.
#44
CT
It also wouldn't hurt to pick up a soldering iron kit from Radio Shack. It will tech you the basics of how to solder, which really will come in handy at some point if you are
going to be getting into electric planes of any size and type. Even for a quick field repair if ever needed.
#46
On my Futaba 8U Supers the TC feature when on will not prevent the ESC throttle from advancing regardless of the % value. Only a mix will accomplish this and does work OK..
On my Hitec I didn't try it as it's assigned to a momentary switch and can't be reassigned to another switch.
#47
My Feedback: (13)
Well, at least you got it working with a mix. I think this is a terrific feature. Half of my planes have high-end ESCs with cut-off switches already hooked up. The half that don't (foamies) I've always been worried about bumping that throttle stick while moving about with it just prior to launch/take-off. No more.
#48
My Feedback: (12)
Throttle cut (hold) is an excellent safety feature. Now, after reading walenda I realized it is not on every transmitter model.
the OP idea of keeping the batt in the plane is not good. Lipos are dangerous and should be handled w care
