How do you un bind a receiver
Let's say I have receiver A in plane #1 everything is set up, the plane flies well. I then want to put receiver A in plane #2. I disconnect the Rx in #1, put it in #2. Do I have to do anything special like totally "un-bind", then "re-bind" or just do any necessary reversing and/or trim changes? Thanks again!
Bill in Pa
Bill in Pa
If you do not have to do any channel reversing it should work right away. However, after you set up the throw amounts and any dual rate or expo then I'd rebind just to make sure the fail safe is properly set to insure throttle cut if you lose signal.
