GWS Beaver
MA
GWS Beaver
I just set up some GWS floats and was going to try them out on an old GWS Beaver.
I took the 2015 Himax out a while back and never tried a 400 in it. Running a 1080 prop, which would be a better choice the stock 350 or a 400 from an E-Starter?
Joe
Joe
My Feedback: (21)
RE: GWS Beaver
If you want the more powerful setup, and you limit prop size, you should pick the drive that spins the prop the fastest. That could be either motor, depending on the gearing and the battery at this point.
What gear ratios come with the E-Starter on the 400 system?
